tychoS Posted June 16, 2007 Share Posted June 16, 2007 2,5 n/a & 2,5 TD diesel filter banjo bolt - 16 mm injection pump bleed screew - 8 mm 90"/110" swivel house filler 11 mm square swivel house drain 10 mm square land rover diffs filler 1/2" female land rover diffs drain 1/2" female LT77 filler 1/2" male LT230 filler 1/2" female Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted June 22, 2007 Share Posted June 22, 2007 Disco 300Tdi. Rear suspension upper link bolts = 1 3/16" AF socket. Upper link to ball joint = 19mm sockets both sides and can be vey tough to split. Rear suspension trailing arm chassis mounts = 1 3/16" AF socket. Rear suspension trailing arm to axle = 24mm socket. 300Tdi rear caliper bolts (12 sided) have an m12 thread and do not fit 200Tdi axles, they're too big. Need 1 size smaller but in Imperial, if that makes sense. Stu. Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted June 30, 2007 Share Posted June 30, 2007 Axle, gearbox and transfer box breathers (Banjo bolts) are 9/16 AF or a tight 14mm. These can be replaced with much better fittings from your local hydraulics/pneumatics store. Thread size is 1/8 BSP. I'd recommend elbow swivels. Quote Link to comment Share on other sites More sharing options...
alan kemp Posted October 3, 2007 Share Posted October 3, 2007 300 tdi belt tensioner 15mm Type R winches - 3/4 Hydrolic hose nuts 27mm Would be a good idea to add the torque setting for each. No idea what the above ones are. Si, I like gusset just as much as flange. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted November 1, 2007 Share Posted November 1, 2007 From post 3 -- "2.5 NA crank pulley nut 41mm". When this bolt incorporates the dog for the starting handle the size is 1+11/16"AF. 43 mm appears to be the nearest Metric size Expect this socket to be 3/4" drive. For the 38A Range Rover: R380 5 Speed Gearbox Drain plug 32mm + Copper Washer, 25mm ID x 32mm OD, Fill plug 55 Torx (Tx) Borg Warner Chain Transfer Box Fill and Drain plug 13mm Female square Axle differentials Fill and Drain plugs 13mm Female Square Glow Plugs Glow tube plugs - one pole, 25x6mm Voltage : 11 Thread : M12x1,25 Spanner width (AF) : 12 mm. Diesel AC Compressor belt tensioner 13mm AF Spanner 10mm AF Allen key. Turn Clockwise. Torx bit list TX40 - Ball Joints on Drag link and Tie bar. Also Front seat base to runners. TX45 - Front Seat Runners to bodyshell. TX55 - R380 5 Speed Gearbox Fill Plug. Wheel Nuts 27mm 80 lbf-ft Brakes Caliper Pin Bolts, Front & Rear 12mm AF 22 lbf-ft Front Caliper to hub bolts 19mm 12 point 122 lbf-ft Rear Caliper to hub bolts 13mm 12 point 74 lbf-ft Brake Disc to hub screws No4 Pozidrive. 18 lbf-ft O Rings Water pump Water pump O ring 68mm x 6mmCS Heater Core O rings. 22 mm ID by 2.5 mm thickness. Use VITON if possible. Has better high temp resistance than the NBR-rubber (Nitrile?) used by LR. EAS Lines to/from the air dryer are 8mm, to the air springs 6 mm, and the venting line is 4 mm. O-rings are those ID, and are 2.5 mm thick. --------------------------------------------------------------------- Quote Link to comment Share on other sites More sharing options...
santalars Posted November 21, 2008 Share Posted November 21, 2008 300 tdi / 90 Drag link lock nut 28mm spanner (never used that one before) 27mm if non original replacement (***tpart) Quote Link to comment Share on other sites More sharing options...
Autokaci Posted December 13, 2008 Share Posted December 13, 2008 Viscous fan nut: thin walled cranked spanner 36mm Oh... BTW...I'm new here!!! Kaci Quote Link to comment Share on other sites More sharing options...
Autokaci Posted December 13, 2008 Share Posted December 13, 2008 Defender, but I assume virtually any Series or 90 / 110 / 130Transmission brake adjuster nut on drum = 17mm spanner or socket No sir...17mm only for Defender, Discovery, etc....Series have a small square sided adjuster that a 1/4" open end spanner fits perfectly in! Cheers, Kaci Quote Link to comment Share on other sites More sharing options...
mr.t Posted February 13, 2009 Share Posted February 13, 2009 Discovery Wheel Thread : M16 x 1.5 Pitch Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 24, 2009 Share Posted March 24, 2009 Disco 2 battery hold down, 11mm nuts Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted April 15, 2009 Share Posted April 15, 2009 200tdi sump plug nut 29mm Quote Link to comment Share on other sites More sharing options...
errol209 Posted August 9, 2010 Share Posted August 9, 2010 Series 2.25 starter dog - 1 21/32" AF Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 9, 2010 Share Posted August 9, 2010 rover diff & propshaft bolts 9/16" UNF (or UNC) the same as propshaft bolts - I know 14mm will do, but 9/16" is the correct socket size. Quote Link to comment Share on other sites More sharing options...
Jindivik Posted December 23, 2020 Share Posted December 23, 2020 What is the socket size for the main and big end caps on a 300 tdi are they a spline or a 12 point head. Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted December 24, 2020 Share Posted December 24, 2020 On 4/24/2006 at 11:02 PM, mpb said: LT230 Transfer Box Drain Plug - 17mm Socket Some are 1/2" square drive female, as are both the fill and drain of the BW transfer on my P38. Quote Link to comment Share on other sites More sharing options...
jason110 Posted December 24, 2020 Share Posted December 24, 2020 Not sure if it’s been posted yet. But found this to be useful Quote Link to comment Share on other sites More sharing options...
