zebs Posted January 23, 2010 Share Posted January 23, 2010 Hi all, I wondered if there are any electrical buff out there to help me with my def 90 dip beam headlight probs. Basically I [With great help of 'Fanatic' on Landzone.co.uk'] found the Dim Dip relay unit, and pulled it out. However, now that I have done that, i get no dipped lights at all, and even when i push it back in the same occurs. I have again checked the fuses but all ok. All I want is to have the dipped headlights working - goodness this is doing my head in, but i will not give in and give hard earned cash to landorver at £90/hr to find this fault. Can anyone help me out here please - my fmaily and i are desperate to get our 'Prettyboy' def 90's dipped working again. In haste Zebs and Family Quote Link to comment Share on other sites More sharing options...
dreadnought110 Posted January 24, 2010 Share Posted January 24, 2010 Dead simple get a test lamp find the feed on the relay block from the dipped beam cicuit and link it to the dipped beam output (blue and red i think) then should be all good (i think i'm right not 100%sure its about 4 years since i last dumped one of these relays) either way you have to link two wires. cheers Quote Link to comment Share on other sites More sharing options...
MRWOO Posted January 24, 2010 Share Posted January 24, 2010 Dead simple get a test lamp find the feed on the relay block from the dipped beam cicuit and link it to the dipped beam output (blue and red i think) then should be all good (i think i'm right not 100%sure its about 4 years since i last dumped one of these relays) either way you have to link two wires. cheers This has happened to me before on a 2007 defender, not sure if the part is similar to 97 year but it was down to the indicator/main/dip stalk. On the TD5 and 2007> defender the stalk comes comes with a multi-task switch that failed. What you decribed is exactly what happened to me. Main bean and flash but no dip Quote Link to comment Share on other sites More sharing options...
