minivin Posted April 25, 2006 Share Posted April 25, 2006 Does anyone know the compressed and extended lengths of a Series III 109 front and Rear Prop? I need to get some new one's made ready for my LT77 conversion so need the lengths to then recalculate what I need Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 26, 2006 Share Posted April 26, 2006 u should be able to use your standard front prop, or a standard length one, yours needs changing though cos its worn. can u not just modify the rear prop u have at the mo, ie shorten it? Quote Link to comment Share on other sites More sharing options...
minivin Posted April 26, 2006 Author Share Posted April 26, 2006 was thinking about getting a wide angle prop on the front as the ears are close to touching the flange when on a level sitting, so dunno what it's doing under full articulation but that could explain why the HS UJ's are already shot. Thought I'd get a decent rear prop made as well rather than trust Britpart quality Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 26, 2006 Share Posted April 26, 2006 u need to do some tests on full droop to find out about yoke bind, i take it u haven't done this then? Quote Link to comment Share on other sites More sharing options...
minivin Posted April 26, 2006 Author Share Posted April 26, 2006 u need to do some tests on full droop to find out about yoke bind, i take it u haven't done this then? no, no facilities, will have to suss somewhere local that has a ramp or summit Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 26, 2006 Share Posted April 26, 2006 u can do it with stands andtake the wheels off for full droop Quote Link to comment Share on other sites More sharing options...
minivin Posted April 26, 2006 Author Share Posted April 26, 2006 Don't fancy doing a reenactment of the Hi Lift saga on gravel Quote Link to comment Share on other sites More sharing options...
minivin Posted April 26, 2006 Author Share Posted April 26, 2006 Prop Lengths? Anyone? Quote Link to comment Share on other sites More sharing options...
RPR Posted April 27, 2006 Share Posted April 27, 2006 Propshaft Clinic in Bradford are the best place to get custom wide angle yolk props along with an extended slip joint- and they will do you a narrow diameter front prop as well. The prices are competitive and the product is good. They know and love their Landies. If nobody has answered by then, give them a bell in the morning and they will tell you, but the best thing to do is measure it yourself, t-case to pinion flange (he, he...flange) and give them the measurements for what you need. I would be a bit leery of having them made on a calculation before you've the new box in situ and are absolutely sure of the lengths.... Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 27, 2006 Share Posted April 27, 2006 they're here, i got my rear from them, good quick service Quote Link to comment Share on other sites More sharing options...
02GF74 Posted April 27, 2006 Share Posted April 27, 2006 Prop Lengths? Anyone? I've got a series prop lying round in the garage, trying hard to remeber but think it is off the back for an 88in so not use really. Quote Link to comment Share on other sites More sharing options...
minivin Posted April 27, 2006 Author Share Posted April 27, 2006 Propshaft Clinic in Bradford are the best place to get custom wide angle yolk props along with an extended slip joint- and they will do you a narrow diameter front prop as well. The prices are competitive and the product is good. They know and love their Landies. If nobody has answered by then, give them a bell in the morning and they will tell you, but the best thing to do is measure it yourself, t-case to pinion flange (he, he...flange) and give them the measurements for what you need. I would be a bit leery of having them made on a calculation before you've the new box in situ and are absolutely sure of the lengths.... Cheers Tonk and RPR for the contact, will give them a try Luckily we know the box moves back 108mm since it's the same conversion that Tonk has done, so will have a looksie at prop angles as well just to confirm how much I need and don't need Quote Link to comment Share on other sites More sharing options...
minivin Posted April 27, 2006 Author Share Posted April 27, 2006 I've got a series prop lying round in the garage, trying hard to remeber but think it is off the back for an 88in so not use really. ah well, it's the thought that counts Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 27, 2006 Share Posted April 27, 2006 if you're gettin some made then u might aswell get them to put in a longer slip joint too, especially on your front prop Quote Link to comment Share on other sites More sharing options...
minivin Posted April 27, 2006 Author Share Posted April 27, 2006 if you're gettin some made then u might aswell get them to put in a longer slip joint too, especially on your front prop yeah that's what I was thinking after I had posted the last message, being steep now on the front prop it could be the slip joint bottoming or topping out and doing the damage to the UJ. Need to talk with Rogue about his ramp by his garage Quote Link to comment Share on other sites More sharing options...
minivin Posted May 2, 2006 Author Share Posted May 2, 2006 Ah well, finally went out and did some tests: The two leaf fronts are going from bump stop to bump stop nay problem, which after putting one front wheel up and then the rear wheel up to compress the other front suspension I found that I had from prop flange face to other face an extended length of 25" and a compressed length of 23". Rear came out at 41" both times so it would seem that the rear axle is swinging from side to side depending on tilt one way or the other to keep the length the same. Only well issue is the front then, and it definately is: Silly angle on the front prop, it didn't seem to be max extended as there was still play in it, but it seemed to be max compressed as there was no play in it which may explain the knackered UJ after very little mileage As the LT77 conversion is going to move the drive flange 108mm rearwards I noticed a bit of room at the front of the crossmember: and at the rear of the cross member: Got me wondering whether a slightly longer prop could be used once the conversions done to reduce the angle at the diff, double cardon could be an option down at the diff nose Quote Link to comment Share on other sites More sharing options...
minivin Posted May 9, 2006 Author Share Posted May 9, 2006 Have placed my order for a front prop, give it a few weeks and will sort the rear prop Quote Link to comment Share on other sites More sharing options...
Hillbilly Rebel Posted May 9, 2006 Share Posted May 9, 2006 Times a tickin M and GM. P.S. no comment on my truck! Quote Link to comment Share on other sites More sharing options...
minivin Posted May 9, 2006 Author Share Posted May 9, 2006 Times a tickin M and GM. P.S. no comment on my truck! I know, won't have the LT77 finished and the disc hand brake till mid june on the projected time scales for manufacture at present, will have to see how it pans out Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted May 9, 2006 Share Posted May 9, 2006 well the Raider wont make it! Quote Link to comment Share on other sites More sharing options...
minivin Posted May 9, 2006 Author Share Posted May 9, 2006 well the Raider wont make it! bless Quote Link to comment Share on other sites More sharing options...
Tonk Posted May 10, 2006 Share Posted May 10, 2006 well the Raider wont make it! i do wish u'd finish your sentences off the drive Quote Link to comment Share on other sites More sharing options...
minivin Posted May 10, 2006 Author Share Posted May 10, 2006 i do wish u'd finish your sentencesoff the drive is that OT or OT Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted May 10, 2006 Share Posted May 10, 2006 This is a LR forum... no chit chat please! Quote Link to comment Share on other sites More sharing options...
minivin Posted May 10, 2006 Author Share Posted May 10, 2006 This is a LR forum... no chit chat please! ahhhh, but it's a Land Rover topic, but it can't be because it don't leave the drive, I need RULES OF ENGAGEMENT!!!!! Quote Link to comment Share on other sites More sharing options...
