bobrick Posted February 1, 2010 Share Posted February 1, 2010 hi ralph i have had a look at my parts catalogues however i was wondering if you might have a better idea. i need a number for the spacer washer or thrust washer (whatever its called) for a discovery 1 axle. its the item that goes between the bearing and the inner hub nut. unfortunatly i dont have any way to identify the axle apart from that i know (but not 100% certain) that it is a disco 1 axle. i tried to find the axle number however its been painted over and i cannot find it. the stub axle has has a flat on it rather than a keyway if that is any help and it is a non abs axle. the numbers i had in my parts diagrams were FTC3185 FTC5241 i have cross referred these on the internet and paddocks throws up defender axle lock washers so i got a bit concerned cheers for looking will Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2010 Share Posted February 1, 2010 for vehicles upto JA032850 use FRC8227 http://www.lrseries.com/shop/product/listing/6688/FRC8227-90-110-STUB-TO-HUB-TRACK-SPACER.html? from chassis TA500000 to TA524102 use FTC3185 http://www.lrseries.com/shop/product/listing/14068/FTC3185-HUB-BEARING-WASHER-SPACER-INNER.html? from TA534103 to VA556998 use FTC5241 http://www.lrseries.com/shop/product/listing/7145/FTC5241-STUB-AXLE-SPACER-WASHER.html? HTH Quote Link to comment Share on other sites More sharing options...
bobrick Posted February 1, 2010 Author Share Posted February 1, 2010 cheers ralph thats a great help, i suspected it was the first one anyway but will get the others as they are only pence just in case cheers will Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2010 Share Posted February 2, 2010 Happy to assist Quote Link to comment Share on other sites More sharing options...
