Salisbury casing spreader wanted
Im on the hunt for a Salisbury casing spreader, (tool number 18G 131C & 2 pegs number 18G 131F) to use to get the diff out of my front axle, has anybody in the midlands got one that i can beg the use of? or buy if the price is agreable. I have already tried the local Landy main dealer as well as a Ford(transit) commercial main dealer, also the local landy garage that does off road prep but no luck. The other possibility is a dimensioned drawing of the tool so i can make one.
Oh im in Rugby Warwickshire. :)
You don't need one, the diffs are easy to pop out.
See here
Put a ring spanner on those nuts so that it is braced against the case
You can then use a pry bar to lever out the other side of the ring gear, it will just pop out !!
Depending on tolerances, it might just go back in, or failing that put the diff centre in the chest freezer for a few hours.
