Dilemma OT
Since Mr Kelly seemed to incite violence but intended to generate debate, I'll have a go.
You are going to buy three vehicles that you don't want to break down and strand you (ie you're going to the desert/mountains/Ipswich, or running a small fleet for a haulage company or something similar). The actual task is unimportant, but your use will be 100% duty (so running 24/7 at the full design speed/load/volume etc). The vehicles will be used hard, but you need to remain mobile. There are no local supplies (not even in Ipswich) and you have a workshop which could be days away.
Question is - do you buy three the same, or three different vehicles? Top of the range, or basic model. Biggest or smallest engine? Turbo or NA? Give similies and draw parallels if you can, show your working, don't cross your hands on the steering wheel.
(Slow day in work, again)
1st year 3 different brands similar spec
then operate for 12months
Aftre the final cost analysis
best VFM replaces the others one at a time dropping the one that has been:
Expensive
suffered lots of downtime
Choices from day one:
Mercedes Sprinter
Fiat Ducato
Vauxhall Vivaro(my 1st choice)
3 different models, all with the simplest, lowest stressed parts availiable. If I could look at the past running history of similar vehicles to find the best, I would.
Basic spec, so that there was less to go wrong - the base parts are the same anyway. Largest, simple (ie. non-turbo) engine possible, so that they have the largest excess of power and therefore hopefully are the least stressed.
If a workshop was closer, I would go for 3 of the same model to reduce the volume of spares needed, therefore increasing profit (works for low cost airlines).
Look at what fleet companies provide as there maintaining them they will be the most reliable.
that is why Land Rovers have only just become available on the fleet buyer market as ford has improved the build quality and reliability to a standard were the big firms will use them.
Lombard do a stonking deal on a TDV6 RRS all in fuel ,insurance ,maintenance, tax everything all you need to worry about is driving it.
My wife even thought it was a good idea but not long enough for me to get her to sign up for it (she gets discounted rates)
VW LT range are very good my dad did 270 miles in three years up till last May with his completely trouble free
Since Mr Kelly seemed to incite violence but intended to generate debate, I'll have a go......
.... (ie you're going to the desert/mountains/Ipswich,....
...(not even in Ipswich)
OI! what's wrong with Ipswich!!! :P:rolleyes:
And er , three vehicles all the same, greater knowledge of faults across the three, preventitve maintainance, pooling resources etc etc.
Like Tony said, got to choose the right vehicle in the first place.
Luke
rather than 3 inferior vehicles, get 6 rusty rangie classics on Lpg/ 200tdi discos according to your fuelling preference, the workshop works full time at first repairing the rust, then after 6 months sell as many as you don't need, for a profit :)
Initially, put all the components in best condition on the 3 working vehicles, then simply observe stringent service/replacement schedules
3 vehicles the same spec, as basic spec as possible (such as XD being tdi not td5s which thye coudl have waited for). therefore spares commonality and only specialist knowledge needed on one platform
i'd go for three vehicles the same, common spares and only get to know one vehicle.
it would be either japanese (honda, nissan or toyota) or german (VW or merc) and diesel.
servicing is they key, halve the time between oil changes, weekly inspections of the underside of the vehicles, no expense spared maintenance.
Jules' fathers experience is not uncommon, if a modern vehicle is maintained properly, as that van must have been, they should be capable of starship mileage.
i'd have a good look at what people like BT, the post office, the motorway cops and TNT use... they all do high miles and need reliability.
most new stuff thsesdays is super reliable, manufacturers wouldn't offer a 3 year warranty if they expected us to realy need it!
The farmer next door to my folks has 4 VX Landcruisers, with mileage between 5K and 120k.... they Never go wrong, and the big 4.2 litre diesel is never stressed... even when towing a huge trailer.
late 1980's toyoya hilux might be a good bet, everytime i stick the channel 4 news on there seams to be one lurking in the background, behind the reporter, loaded to the max with twenty blokes, a dog and a couple of RPG launchers.... :)
the Toyota Taliban... the go where you like, do what you like, take what you like vehicle.... ;)
I would opt for the Mercedes Sprinter and the lower tech current model VW LT - two of one one of the other? Both non-turbo options although turbos can get better MPG. Van wise I would not touch anything French/Italian I am afraid. If load carryting were not a requirement then something Japanese would be high on the list.
Chris
OK, some good answers and a mixture of choices.
Now you're doing the same thing (long expedition, 6 months of fleet work or similar) and you have access to a field workshop but no parts AT ALL. How does that change things?
as thin as Mr Turbocharger!
^^ just jealous :P
^^ just jealous :P
Simple
jack and find another job that has some facilities. :)
