Disty Posted February 8, 2010 Share Posted February 8, 2010 First post, so Hi all! After my last landy was stolen I managed to get hold of a low mileage 300tdi! The paint is light blue, i've attached a photo- i presume this is Arles blue? (yes, i have checked out these Paint Codes) My question is, where do I buy this paint from? Is it easier to apply as a spray paint, or will normal paint give me a good finish? I also want to buy white paint to clean the roof up somewhat.. Excuse the pic! Also, while I'm asking.. how essential is it to change the timing belt on my 300tdi? I've had a bit of experience (lift kit etc.) but am no mechanic.. Cheers! Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted February 8, 2010 Share Posted February 8, 2010 Do you know when the belt was changed? If not, DO IT NOW!! But seriously, it's not too difficult, read Les' write up here. Read through it first to make sure you have all tools required before starting. My belt was half snapped when I did mine (just in time)! Quote Link to comment Share on other sites More sharing options...
milliejasper1111 Posted February 8, 2010 Share Posted February 8, 2010 Hi there, Regarding the paint, if you have any good motor factors that supply to the bodyshop trade in your area, they will be able to take your paint code and match it for you, in either in a spray can, half ltr,1 ltr,etc etc, or Halfords may have some in spray cans? if no joy there, there are a few people (shops) in Ebay that can do it for you, just give them the code (bit over priced though) what with postage. Paint code will be on the I.D plate (next to trim code etc) Regarding cam belt, do it! one of the first things i do when getting a new car I had one go on me, a few years ago even though i was assured it had been done so i tend to do it now for piece of mind. They are not that bad to do on the 300, crank shaft bolt can be a bit of a pain! Whats the mileage on it?? Ian Quote Link to comment Share on other sites More sharing options...
Malcyt Posted February 8, 2010 Share Posted February 8, 2010 Hi and Welcome.... I've recently been looking myself, these guys seem to offer a comprehensive range and a#can even hand match custom colours which is what I need as my 90 was resprayed but I have no idea of what colour code. hope this helps http://www.autopaintsbrighton.co.uk/car-paints-custom-mixed--touch-up-kits-18-c.asp Quote Link to comment Share on other sites More sharing options...
Disty Posted February 8, 2010 Author Share Posted February 8, 2010 Thanks guys, I'll get the belt changed asap.. just have to drive it back from Scotland first! eech! Where did you get your kit from? That link is useful, thanks- any ideas what primer I should be using? Quote Link to comment Share on other sites More sharing options...
milliejasper1111 Posted February 8, 2010 Share Posted February 8, 2010 Thanks guys, I'll get the belt changed asap.. just have to drive it back from Scotland first! eech! Where did you get your kit from? That link is useful, thanks- any ideas what primer I should be using? I would go for good "high build" primer, there are quite a few on the market, Cant go wrong with PPG, Depends on your budget is, same again you can buy it by the ltr or in a spray can. Have a look in the various LR mags, your local motor factor, most places do cambelt kits, go for a full kit, as they are not much more than buying the belt itself! then you get all the seals, crank pully, gaskets,etc etc Quote Link to comment Share on other sites More sharing options...
timmymac Posted February 9, 2010 Share Posted February 9, 2010 do you want to paint it because it looks faded/ marked or because it does really need a paint. i say this because a buffing head and G3 polishing compound are much cheaper than paint and can make a suprising difference. Quote Link to comment Share on other sites More sharing options...
