td5_2004 Posted April 28, 2006 Share Posted April 28, 2006 does anybody know how can i upgrade my td5 turbo? has anyone done it yet. for which turbo should i go for. please help, i need more power Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted April 28, 2006 Share Posted April 28, 2006 A larger intercooler and a remap of the ecu is the customary start point. Quote Link to comment Share on other sites More sharing options...
td5_2004 Posted April 28, 2006 Author Share Posted April 28, 2006 i already done that. now i want to upgrade the turbo to a variable nozzle one. i already have one off a mercedes on the way, i will see how it does. but if someone has anymore ideas please post here. Quote Link to comment Share on other sites More sharing options...
Guest MJG Posted April 28, 2006 Share Posted April 28, 2006 .a Quote Link to comment Share on other sites More sharing options...
Steve H Posted April 29, 2006 Share Posted April 29, 2006 Lara was going down this route for his 2.8 TD5, don't know how far he has got, check him out in members vehicles & maybe PM him. Cheers, Steve. Quote Link to comment Share on other sites More sharing options...
freeagent Posted April 29, 2006 Share Posted April 29, 2006 track down Bruce from the Tombraider club, he's on here quite a lot 'TOMBRAIDER110' i think.... he knows a bit about this as his Td5 is putting out nearly 200bhp.... m@tt Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted April 29, 2006 Share Posted April 29, 2006 i already done that. now i want to upgrade the turbo to a variable nozzle one. i already have one off a mercedes on the way, i will see how it does. but if someone has anymore ideas please post here. Ah well you should have said that in the first place Quote Link to comment Share on other sites More sharing options...
Guest MJG Posted April 29, 2006 Share Posted April 29, 2006 Ah well you should have said that in the first place My thoughts exactly except I put it a little more forcefully then edited the post (see they can't be deleted now) so as not to cause offence to anyone..... Quote Link to comment Share on other sites More sharing options...
Lara Posted April 29, 2006 Share Posted April 29, 2006 I will post info and pics as soon as my new VGT unit is on and tested, making the manifold at the moment. Lara. Quote Link to comment Share on other sites More sharing options...
td5_2004 Posted May 4, 2006 Author Share Posted May 4, 2006 here is an update. yesterday i recieved the Gt22v Turbo off a mercedes E270. its massive compared to a standard td5. we immediately opened it to see the mecanism, and it has another set of blades (variable). it needs lots of modifications like manifold and exaust. now here is something we did not understand. the actuator is vacuum operated. can someone help us how to do it? how does the vacuum actuator work? Rodney Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 4, 2006 Share Posted May 4, 2006 Brake servo? hat/coat/slam!...... Quote Link to comment Share on other sites More sharing options...
andylandy Posted May 4, 2006 Share Posted May 4, 2006 it needs lots of modifications like manifold and exaust no sh*t sherlock i know andy at allisport are working on this at the momment but be warned upgrading a turbo on a td5 will need specific fuel mapping to make it work properly give him a call and see how he`s getting on Quote Link to comment Share on other sites More sharing options...
jules Posted May 4, 2006 Share Posted May 4, 2006 Fit a V8 Ok I'll get my coat. My 2.0 TD4 has about 200 bhp you must be able to get more than that out of it Quote Link to comment Share on other sites More sharing options...
pugwash Posted May 4, 2006 Share Posted May 4, 2006 ahh jules i was just getting there but you beat me to id. my advice- unbolt the dieselly bit, buy another turboo, and run with a trwin turbo V8 setup. The turbos won't last long i guess (i assums TD5s are variable geometry turbos) but you'll at least have some fun! Quote Link to comment Share on other sites More sharing options...
td5_2004 Posted May 4, 2006 Author Share Posted May 4, 2006 i already talked to andy, they did not come up with anything yet. the only person that might help here is Lara or anyne that has a 2.8 tgv installed. i will try to find a boost actuator or try to fit a normal waste gate. as regards to the ECU mapping i have already worked on that. any other ideas? Quote Link to comment Share on other sites More sharing options...
LR90 Posted May 4, 2006 Share Posted May 4, 2006 So assuming it has a stockish wastegate what does this vacume actuator actuate? It might then be more obvious where to plumb it in (perhaps tapping differential pressure somewhere) or even plumbs into the vacume pump but with an ECU switch solenoid so that its actuation is under programatic control. Quote Link to comment Share on other sites More sharing options...
Bush65 Posted May 5, 2006 Share Posted May 5, 2006 I have a 2.8 TGV turbo on my 300Tdi. Don't know about what they use on Mercs. The VW Tdi are vacuum operated (computer controlled I assume). The actuator (for vane control) on the 2.8 TGV turbo is not vacuum - it gets pressure directly from the outlet of the compressor. Quote Link to comment Share on other sites More sharing options...
Bush65 Posted May 5, 2006 Share Posted May 5, 2006 So assuming it has a stockish wastegate what does this vacume actuator actuate?It might then be more obvious where to plumb it in (perhaps tapping differential pressure somewhere) or even plumbs into the vacume pump but with an ECU switch solenoid so that its actuation is under programatic control. They don't have a wastegate. The actuator controls the angle of the vanes (so called varaible nozzle) in the turbine inlet, to control boost pressure. In essence it is variable A/R ratio. Quote Link to comment Share on other sites More sharing options...
Michele Posted May 5, 2006 Share Posted May 5, 2006 I have a 2.8 TGV turbo on my 300Tdi. Performance report? Quote Link to comment Share on other sites More sharing options...
jules Posted May 5, 2006 Share Posted May 5, 2006 I have a 2.8 TGV turbo on my 300Tdi.Don't know about what they use on Mercs. The VW Tdi are vacuum operated (computer controlled I assume). The actuator (for vane control) on the 2.8 TGV turbo is not vacuum - it gets pressure directly from the outlet of the compressor. Have you looked at the uprated inter-coolers from JE or Jeremy fearn. and the ECU upgrades from JE they built my 200 bhp TD4. My mate had a TD5 90 that could spin on tarmac all in first second and third on 265 BFG AT's it was fitted with a JE phase two kit Quote Link to comment Share on other sites More sharing options...
Bush65 Posted May 5, 2006 Share Posted May 5, 2006 Have you looked at the uprated inter-coolers from JE or Jeremy furn.and the ECU upgrades from JE they built my 200 bhp TD4. My mate had a TD5 90 that could spin on tarmac all in first second and third on 265 BFG AT's it was fitted with a JE phase two kit I suspect you may have quoted the wrong post. Why would I be bothered to do any of that? I'm in Aus. We never got computer controlled 300 Tdi. As far as intercoolers go, I have a good, custom built, air to water intercooler from A R E a little larger than what they normally fit to 4.2 litre Land Cruiser diesels. As far as TD5 chips go the ones from Bruce davis here in Aus, perform as well or better than most. Quote Link to comment Share on other sites More sharing options...
Bush65 Posted May 5, 2006 Share Posted May 5, 2006 Performance report? I never ran the stock 300Tdi after swapping it for the v8, so I have no benchmark. Never been on a dyno either, and IMHO dynos figures should be taken with a grain of salt if comparing different vehicles with big differences in gearing, tyre size etc. Quote Link to comment Share on other sites More sharing options...
Michele Posted May 5, 2006 Share Posted May 5, 2006 I never ran the stock 300Tdi after swapping it for the v8, (...)and IMHO dynos figures should be taken with a grain of salt True,but I meant sheer feeling...! If you haven't run the engine yet my question drops though P.S. As usual,should you have any pic of the VGT fitted to the stock 300 I'd like to drool over a bit Quote Link to comment Share on other sites More sharing options...
jules Posted May 5, 2006 Share Posted May 5, 2006 I suspect you may have quoted the wrong post.Why would I be bothered to do any of that? I'm in Aus. We never got computer controlled 300 Tdi. As far as intercoolers go, I have a good, custom built, air to water intercooler from A R E a little larger than what they normally fit to 4.2 litre Land Cruiser diesels. As far as TD5 chips go the ones from Bruce davis here in Aus, perform as well or better than most. Sorry it was the Td5 Turbo title that I miss read. I have a inter-cooler that is half again the surface area of a Disco two radiator and three times the depth fitted in the freelander the only this I have seen bigger was towing 44t. There was a Bowler 200 wildcat running a very played with 300tdi that was quick but my freelander was beating it 45 sec per 9 mile lap on the Scottish round of the British off road championships last year. Ali fly's back out late July Quote Link to comment Share on other sites More sharing options...
Bush65 Posted May 5, 2006 Share Posted May 5, 2006 ...I have a inter-cooler that is half again the surface area of a Disco two radiator and three times the depth fitted in the freelander the only this I have seen bigger was towing 44t. ... Pi$$ ant stuff If you want to see an intercooler check this 1500 kW Holden road car here. This was built by the person that made my air to water intercooler. Quote Link to comment Share on other sites More sharing options...
