Sheepshed Posted February 20, 2010 Share Posted February 20, 2010 Hi all, Have started losing oil from the end of the front axle - but discs are clear and not contaminated. All the oil is coming out through the rubber end cap on the hub with none inside the wheel - does this sound like the stub axle oil seal. Not sure if oil is leaking from the swivel or through from the diff? Any help appreciated. Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 21, 2010 Share Posted February 21, 2010 You need to remove the cap, clean it and the drive flange up and then refit the cap with a bead of RTV silicon sealant. The hub seal is inboard, and would contaminate the inside face of the brakes. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 21, 2010 Share Posted February 21, 2010 That's good..At least the flange splines are being lubricated. As has been said. Cap off and clean, check for splits, any splits then renew the cap. Make sure that the hub face where the cup its is clean. A drop of EP90 in the cap before fitting helps the splines. Now check the axle breathers just to make sure they aren't blocked. Quote Link to comment Share on other sites More sharing options...
errol209 Posted February 21, 2010 Share Posted February 21, 2010 That's good..At least the flange splines are being lubricated. As has been said. Cap off and clean, check for splits, any splits then renew the cap. Make sure that the hub face where the cup its is clean. A drop of EP90 in the cap before fitting helps the splines. Now check the axle breathers just to make sure they aren't blocked. This can also be a symptom of knackered splines on the shaft and / or drive member, leaving a space which acts as a pump. Quote Link to comment Share on other sites More sharing options...
