kevin Posted February 22, 2010 Share Posted February 22, 2010 I have found a a hole the size of a 10p under a blister on the door pillar (bulkhead) halfway down the post between the hinges is this an mot failer as the landy is booked in for wed am and it may be to soon to get repaired. ps its about a foot from both hinges. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 22, 2010 Share Posted February 22, 2010 I have found a a hole the size of a 10p under a blister on the door pillar (bulkhead) halfway down the post between the hinges is this an mot failer as the landy is booked in for wed am and it may be to soon to get repaired. ps its about a foot from both hinges. If thats the only hole will a sticker not cover it for the MOT!!! until you can sort it out!! or you could go down the route that lots seem to do these days and stick some checker plate over it on a serious note don't just leave it rust prevention/conversion may save you replacing the whole thing next year and make it repairable. Cheers, Jason. Quote Link to comment Share on other sites More sharing options...
WarPig Posted February 22, 2010 Share Posted February 22, 2010 Ive got the same problem. One side went a few years ago but I got it repaired. Now the other side as gone in the exact same place. Wonder what causes it to go in that particular place? Quote Link to comment Share on other sites More sharing options...
LandyLee Posted February 22, 2010 Share Posted February 22, 2010 for it to be a mot item it would have to be in a prescribed area , i.e within 12 inches of brakes or suspension or steering and I can`t see it being there if it`s where I think. if you fill it or cover it it would get a mention as a manual advisory to say area not testable due to covering ,, Quote Link to comment Share on other sites More sharing options...
kevin Posted February 23, 2010 Author Share Posted February 23, 2010 So i take it they won't class it as being a structure area? btw i have rebooked the test and will be repairing it.Does anbody know if i can get a replacement panel as i only seem to be able to find the corner panels on the internet. Quote Link to comment Share on other sites More sharing options...
RaDi90Hybrid Posted February 23, 2010 Share Posted February 23, 2010 When I did mine I clean all the crud away and filled the hole with weld, as mentioned before it may not even be failable. (The first time I spotted it was on the day before the MOT so that year I did a greenlane and did not give it a REALLY good clean if you get my drift!) Quote Link to comment Share on other sites More sharing options...
