tonko007 Posted February 27, 2010 Share Posted February 27, 2010 hi all i own a 1996 2.5 tdi in the last month or so i have noticed that when i start from cold and start to drive there is no power there and really struggles until i have driven about half a mile if that and all is back to normal your help would be much appreciated thanks paul Quote Link to comment Share on other sites More sharing options...
Juz Posted February 27, 2010 Share Posted February 27, 2010 Pull out your injectors and have a look at them. Only takes 10 mins. Juz Quote Link to comment Share on other sites More sharing options...
SPendrey Posted February 27, 2010 Share Posted February 27, 2010 I thought that was 'normal' for a 300TDI? Mine does it too! Quote Link to comment Share on other sites More sharing options...
George1 Posted February 27, 2010 Share Posted February 27, 2010 Hi Paul First and foremost, did you check that all the filters and the sedimenter are clear and that the pre-feed pump is working correctly. If the above is all normal, then the symptoms you describe point towards pump timing rather on the late side. The Bosch Diesel pump needs to advance during cold start. If there is now already a timing error on the late side present, this will amplify the problem. Take the car to a shop, where they can check the pump timing with a timing light. this is possible with a nifty little device from Snap On, which detects the pulse from the No. 1 injector pipe and converts this into a signal, any normal (high quality) timing light can interprete. Pump timing should be at 10Deg BTDC. Good luck George Discovery 300Tdi ES Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted February 28, 2010 Share Posted February 28, 2010 Change fuel filter, check lift pump by checking for strong pulse of fuel from filter bleed point when the engine is running. Also check sedimenter. Quote Link to comment Share on other sites More sharing options...
