myzeneye Posted February 27, 2010 Share Posted February 27, 2010 hi guys...hope you can help... i bought a freelander, 05 plate, 40k TD4... after a few weeks and a bit of reading up i suspected the viscous coupling was shot... got it in at my mates garage, the plan was to change the vc and do a thorough service as well....... it didnt quite go to plan........... doh!!!!!! we removed the prop and vc unit but on closer inspection the bearings in the ird output seemed a bit poorly/ notchey ? the crown /pinion etc seems fine though..i think ive just caught it before the whole thing went bang..... luckily my mate is a gearbox specialist so all that is in hand...he's gonna remove the ird, split it open and renew all the bearings and seals etc... were im stuck is the oil filler plug on the ird..... when i wound out the plug it brought a load of swarf with it....it now has NO thread !!! the car was previously serviced by Landrover and this must have been done by them !!.......they were last to touch it... when we wound it out it came out quite stiff... all that was left of the thread was some bits of swarf !! so, other then trying to find a replacement casing, does anyone have any other idea's ?? i think with the verniers the plug was aprox 22mm dia.... not sure weather i can get a larger one and tap the case etc or if theres some kind of heli coil kit etc.......... man im annoyed at the bag of carp i bought. but hopefully when all this is sorted i should have the car i thought i was buying.............. if any one can tell me exactly what size the plug is or point me in the right direction for a helicoil (never used one ?sorry) i be great full... or if you have any other idea's.. maybe a larger plug and tap it out when its split for bearing rebuild..if so and you can recomend a specific larger plug from another vehicle id be VERY greatfull.... thanks guys.. Quote Link to comment Share on other sites More sharing options...
western Posted February 27, 2010 Share Posted February 27, 2010 Cut a new thread & manufacture a larger plug or repiar the thread with a heliciol kit & fit a new standard plug. Quote Link to comment Share on other sites More sharing options...
myzeneye Posted February 28, 2010 Author Share Posted February 28, 2010 i can get hold of some taps and suppose i can get a new larger plug to suit from somewhere... if any one knows what size the original one is let me know as mine is completely buggered....so ive not gone anything to work from... better still if anyone can tell me what size tap to use and replacement plug to get , well, that'd be great....(im not to hot with this kind of stuff..) trouble is, if i go into a motor parts centre, id probably just have to ask for a sump plug for a ????mondeo/laguna/bmw x5 etc ..you know,a specific model car... rather then ask them for a specific thread size/pitch.........i have no idea where to start....................................... Quote Link to comment Share on other sites More sharing options...
western Posted February 28, 2010 Share Posted February 28, 2010 Your gearbox specialist mate should be able to repair or make a new plug/thread. Quote Link to comment Share on other sites More sharing options...
myzeneye Posted February 28, 2010 Author Share Posted February 28, 2010 yeah he can probably sort it but if theres any runnin round for finding odd size plugs or taps etc, well then ill sort that for him to save him the hassle... yeah ive just been looking .... i think the original is 22mm dia 1.5 pitch thread....... if i tap it out to 5/8"bsp and get a new 5/8"bsp plug that should do it..... 5/8"bsp o.d is 22.9 mm.... trouble is, that'l only give me a thread depth of approx .9mm....bsp should really be around 1.9mm deep so..... its close....ish.... cant really go much bigger as its kinda rebated on in the casting of the case.... i dont know much about metric sizes (im old school im afraid) if the original is 22mm o.d, what would be the next easiest size tap and plug to get hold of ? 24mm ??? where would i get that from ???? Quote Link to comment Share on other sites More sharing options...
myzeneye Posted March 5, 2010 Author Share Posted March 5, 2010 bought a new casing from a breakers in the end...60 quid......... Quote Link to comment Share on other sites More sharing options...
