How do you cut a rectangular hole for a rocker switch ?
RichardAllen
Is there an easy way to cut a rectangular hole 19mm x 13mm for a rocker switch in, say 1mm aluminium ?
Last time, I marked, drilled and filed and it took quite a time to get a good fit. I did not think of using an old chisel.
Any better ideas ?
All help gratefully received.
Regards
Richard
PS THis http://ae.rsdelivers.com/product/m10-rectangular-hole-cutter-193x131mm/0600155.aspx is what I have in mind, just cheaper.
Any better ideas ?
Regards
Richard
You use a drill made for drilling square holes of course ,-)
http://bbs.homeshopmachinist.net/showthread.php?t=92&page=4
The Math behind the drill, the "Reuleaux triangle"
http://en.wikipedia.org/wiki/Reuleaux_triangle
As for a quick, dirty and cheap approach for drilling one or a few holes in thin aluminium that does not have to be super perfect, I use ordinary round drills and small files.
