lapperz Posted March 1, 2010 Share Posted March 1, 2010 hi just want to know is it essential to have the bumpstops, as my brackets have rotted away, is it possible i could make my own, even if there only around £3 to buy Quote Link to comment Share on other sites More sharing options...
western Posted March 1, 2010 Share Posted March 1, 2010 IIRC if the bumpstop rubbers are missing it's not a reason for a MOT fail http://www.motuk.co.uk/manual_240.htm see right hand column paragraph 3. but having them will stop the axles bashing the chassis. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 1, 2010 Share Posted March 1, 2010 One missing three fitted and it's a fail. None fitted and it should be a pass Quote Link to comment Share on other sites More sharing options...
lapperz Posted March 1, 2010 Author Share Posted March 1, 2010 i havent got any i will proceed without and fitt them later Quote Link to comment Share on other sites More sharing options...
jericho Posted March 1, 2010 Share Posted March 1, 2010 My rear tyres (35s) hit the underside of the wheel boxes at full flex without stops - they bent the paneling quite badly after one heavy landing. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted March 1, 2010 Share Posted March 1, 2010 I have bumpstops on the front but not on the rear, has been like that for at last 5 years. I noticed that the front needed the bumpstops at standard height while off roading, but with a 2" lift they have not been necessary Quote Link to comment Share on other sites More sharing options...
Orange Posted March 1, 2010 Share Posted March 1, 2010 You also need to make sure (if you are running modified suspension) that the shocks don't bottom out before the axle hits the chassis. Otherwise you will end up with broken/bent/knackered shocks... It can also mean the difference between the diff hitting the sump and clearing it... Quote Link to comment Share on other sites More sharing options...
JST Posted March 2, 2010 Share Posted March 2, 2010 You also need to make sure (if you are running modified suspension) that the shocks don't bottom out before the axle hits the chassis. ^^^^^ what he said Quote Link to comment Share on other sites More sharing options...
