basquen Posted March 3, 2010 Share Posted March 3, 2010 Hi, Just spotted a pin hole leak on the rear diff pan cover. on my 94 300tdi. I've got the choice of complete pan replacement using a weld-on pan (under £25 in parts but I'll need to find a good welder) or patching with liquid metal. The second solution sounds quicker but I guess I might just be putting things and off and it'll go again (sooner rather than later). I've yet to clean up the axle to have a good look at the rest but could be the first sign of more rot to come... Anyone tackled this job recently ? Thanks Nick Quote Link to comment Share on other sites More sharing options...
andyb Posted March 3, 2010 Share Posted March 3, 2010 Liquid metal can be used at a pinch, but you need to make sure the casing is very clean. By which time you might as well weld in a new diff pan or replace the casing with a good replacement one. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 3, 2010 Share Posted March 3, 2010 As Andy says - you can use liquid metal, or it can be plated - the weld would have to be good though. Replacing a diff pan - http://forums.lr4x4.com/index.php?showtopic=39815 Les. Quote Link to comment Share on other sites More sharing options...
basquen Posted March 3, 2010 Author Share Posted March 3, 2010 Thanks for the feedback. I'd already checked out your tech archive Les - really clear - will be a great help. I'll have a good clean up & inspection this weekend and make a decision. Cheers Nick Quote Link to comment Share on other sites More sharing options...
