Hillbilly Raider Posted May 2, 2006 Share Posted May 2, 2006 used the Weaco 240 fridge at the weekend via the 600 inverter in the Raider. Want to use it in the series but the inverter in that is only 300. Will it be able to cope? or should i swap them over? Ta muchly Mandy( Angelina look a like according to Bippie ) (still giggling over that one!) Quote Link to comment Share on other sites More sharing options...
reads90 Posted May 2, 2006 Share Posted May 2, 2006 Mandy( Angelina look a like according to Bippie )(still giggling over that one!) what at the moment or when she was in tomb raider Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted May 2, 2006 Author Share Posted May 2, 2006 more like when she is 50!!! LOL! Did make me giggle! but back to the point of the thread Ali..... will it do the job? Quote Link to comment Share on other sites More sharing options...
western Posted May 2, 2006 Share Posted May 2, 2006 Just check your fridge model here ---- http://www.waeco.com/en/226.php & http://www.waeco.com/en/253.php to the right is product overview links to each model, the biggest needs 60watts so your 300watt inverter will be well on top of the job. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 3, 2006 Share Posted May 3, 2006 I wonder what ooooooomph it needs to start though? On Dad's farm (as on all farms here) they generate their own electricity. The generator is only putting out 10-15 amps as a base load with freezers etc running but when it first comes on and all the compressors fire up in about ten freezers simultaneously the ammeter can hit 80-100 amps ... generators can put that sort of surge out briefly but inverters often can't, so a much bigger inverter is often needed to start an inductive load like a compressor motor. Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted May 3, 2006 Author Share Posted May 3, 2006 it is this one if thats any help? (i also ran i on the mains for 24hrs before i put it in the truck) http://www.waeco.com/en/252.php Quote Link to comment Share on other sites More sharing options...
Les Brock Posted May 3, 2006 Share Posted May 3, 2006 Electrics head on........ To Convert AMPS to WATTS: Multiply: AMPS X 230 (AC voltage) = WATTS This formula yields a close approximation of the continuous load of the appliance To Calculate approximate Startup Load: Multiply: WATTS X 2 = Starting Load This formula yields a close approximation of the starting load of the appliance, though some may require an even greater starting load. NOTE: Induction motors such as air conditioners, refrigerators, freezers and pumps may have a start up surge of 3 to 7 times the continuous rating. Most often the start up load of the appliance determines whether an power inverter has the capability to power it. For example, you have a freezer with a continuous load of 4 amps, and a start up load of 12 amps: 4 amps x 230 volts = 920 watts continuous 12 amps x 230 volts = 2760 watts starting load You would need an power inverter with peak-surge rating greater than 2760 watts. FORMULA to convert AC Watts to DC Amps: AC Watts divided by 12 x 1.1 = DC Amps (this is the size vehicle alternator you would need to keep up with a specific load; for example, to keep up with a continuous draw of 1000 watts, you would need a 91 amp alternator) Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 3, 2006 Share Posted May 3, 2006 It doesn't really help with determining the peak - but if it is a compressor designed to run off an inverter (which it might be on something like that) it may have a "soft start" facility to reduce the peak current draw. Try it and see is the only way to find out! If your inverter goes "bzzzzbeepbeepbeepbeepbeepbeepbeepbeepbeepbeepbeep" it probably means it didn't like it Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted May 3, 2006 Author Share Posted May 3, 2006 Helpful as ever Bog!? Here i am talking about some thing OT for a change and i still get abuse! LOL! Quote Link to comment Share on other sites More sharing options...
western Posted May 3, 2006 Share Posted May 3, 2006 Looking at that fridge range on the link Mandy supplied, the smallest runs at 35watts & biggest at 65watts, so I reckon a 300watt inverter would be OK Quote Link to comment Share on other sites More sharing options...
