minivin Posted May 3, 2006 Share Posted May 3, 2006 and the frame is not removable? hence the problem is now clear. dunno then. from what I could see it's an aluminium 1" box section tube that's sewn into the tent, could be done but the frame I think is the main problem Quote Link to comment Share on other sites More sharing options...
GBMUD Posted May 3, 2006 Share Posted May 3, 2006 The solution is simple. I will even lend it to you... Chris Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted May 3, 2006 Author Share Posted May 3, 2006 you wouldnt get it back! Problem is some of the tracks we drive are too twisty for a trailer. Anyway i have had a word with the Lovely Anton at WWW. OEC4x4.com( not spamming i hope?) and he and the boys in the design shop are going to put their heads together for me!!!!! something on the lines of Minivins idea. Thanks to all of you for all your help. Mandy. Quote Link to comment Share on other sites More sharing options...
Diff Posted May 3, 2006 Share Posted May 3, 2006 Thanks Diff for your advice but as Minivin said we have one sat in the back which is centre mounted behind the 2 front seats and daughter is on it.and stuff on the cubby box.Will the canvas hoops take the weight?if the tent is put on them? Mandy. Yes, the hoops will easily cope with that weight, on and off road, providing you strap it down properly to minimise movement in all directions. It will take a little experimenting on which points work best to strap it to. Once you have worked out a system, you just do the same each time you load it up. The thing to watch out for are rubbing/chafing from ropes or the tent on the canvas. You may need some thing to go under the ropes/straps in places to avoid this. No problem with putting it in the centre on top as the hoops are curved. Likewise, towards the edge won't make any significant difference with regard to uneven loading. To minimise any movement/sliding of the tent on the canvas, put a piece of foam or foam rubber between the tent and the canvas. Regards, Diff Quote Link to comment Share on other sites More sharing options...
minivin Posted May 3, 2006 Share Posted May 3, 2006 you wouldnt get it back! Problem is some of the tracks we drive are too twisty for a trailer. Anyway i have had a word with the Lovely Anton at WWW. OEC4x4.com( not spamming i hope?) and he and the boys in the design shop are going to put their heads together for me!!!!! something on the lines of Minivins idea. Thanks to all of you for all your help. Mandy. I'll have 10% royalties thanks! Quote Link to comment Share on other sites More sharing options...
jules Posted May 3, 2006 Share Posted May 3, 2006 why not buy a kit cage then get Tonk or Stunning to fit it. then fix a normal roof rack to it. Buy a 88 hard top and roof rack Quote Link to comment Share on other sites More sharing options...
Tonk Posted May 3, 2006 Share Posted May 3, 2006 that is the easiest way of doing it, can do that now i've mended the chassis cos theres somewhere to mount it now Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted May 3, 2006 Author Share Posted May 3, 2006 Time and money as said before! Cage is next Tonk project after Ireland/Italy. Quote Link to comment Share on other sites More sharing options...
