defender dinky Posted March 12, 2010 Share Posted March 12, 2010 hi all, d90 1987 disco 200tdi engine in it,ajusted alan key on top of steering box until i have got loppy steering in a straight line, but it still pulling my arms out when turning right and left, bled box 3/4 times, checked preload 3 tmes some say preload 14/16lb& some 6lb and 6/7kg, tried them all but still the same hard cornering, i did notice yesterday that panard bolt were rattling inside the busbes have i put the wrong bolts in after rebuild, would this cause so much trouble with steering cheer's defender dinky Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 12, 2010 Share Posted March 12, 2010 Panhard rod will have nothing to do with it. I would suspect the pump or the box. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted March 12, 2010 Share Posted March 12, 2010 Check the drag link. The rear one could be either too long or short!! Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2010 Share Posted March 13, 2010 DD, check these nominal lengths as highlighted in orange & centralise the steering box, if these don't make any difference, then I suspect the steering box is the culprit. I got the track rod nominal length from the Discovery manual on my RAVE CD's, as Discovery & 90/110 have the same wheel track of 58.5inches, this will worked as I've reset my steering track rod last weekend & it worked a treat. Quote Link to comment Share on other sites More sharing options...
KKMobile Posted March 13, 2010 Share Posted March 13, 2010 have you checked uj's on steering column ??? mine weresiezed when i first got it made the steering hard & wouldn't centre. checked all the usuals but that. ended up doing the bearing in the bottom of the column before i found out whatit was!! Quote Link to comment Share on other sites More sharing options...
dantd5 Posted March 13, 2010 Share Posted March 13, 2010 ^^^^^^ Ralph you do not cease to impress!!! Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2010 Share Posted March 13, 2010 Thanks Dan, had to set up my 110's steering, so went the full whack & dug up the nominal length measurements. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted March 13, 2010 Share Posted March 13, 2010 I know how it is when there is a mismatch or a tight steering. I got a similar problem after I changed from the "chocolated-brittle-biscuitlike" drag link I had. I got a Sumo link and had to use several days finding the center..... The drawing is wicked!!!! Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2010 Share Posted March 13, 2010 one thing I think LR missed out of the 90/110/Defender workshop manual is the distance between pin centres for the track rod, But strangely it's in the Disco 1 manual.just bog standard steering tubes on my 110. Quote Link to comment Share on other sites More sharing options...
diver110 Posted March 13, 2010 Share Posted March 13, 2010 Another thank you for that info. Ralph, Very handy that. Quote Link to comment Share on other sites More sharing options...
western Posted March 13, 2010 Share Posted March 13, 2010 your welcome Quote Link to comment Share on other sites More sharing options...
dantd5 Posted March 14, 2010 Share Posted March 14, 2010 one thing I think LR missed out of the 90/110/Defender workshop manual is the distance between pin centres for the track rod, But strangely it's in the Disco 1 manual.just bog standard steering tubes on my 110. Did you say one thing ??? Many many things to which they supposedly ignore to acknowledge and update. It is a landy thing I guess...... Quote Link to comment Share on other sites More sharing options...
defender dinky Posted March 14, 2010 Author Share Posted March 14, 2010 Did you say one thing ??? Many many things to which they supposedly ignore to acknowledge and update. It is a landy thing I guess...... hi all i checked uj's on coloum they are ok, i will check measurements on trackrod so kindly supplied by western but can't do it til next weekend playing golf all week down oakhampton, so thanks again for your replies defender dinky Quote Link to comment Share on other sites More sharing options...
ajh Posted March 14, 2010 Share Posted March 14, 2010 have you checked uj's on steering column ??? mine weresiezed when i first got it made the steering hard & wouldn't centre. checked all the usuals but that. ended up doing the bearing in the bottom of the column before i found out whatit was!! How did you get bearings? Everyone I have talked with says they are not available from anywhere. Quote Link to comment Share on other sites More sharing options...
