landroversforever Posted March 15, 2010 Share Posted March 15, 2010 Where can I find the engine number on a 200tdi? I believe it is a discovery engine. Thanks in advance!! Quote Link to comment Share on other sites More sharing options...
white90 Posted March 15, 2010 Share Posted March 15, 2010 On the block Left hand side when viewed stood at the front next to where the injector pump is mounted just above the alloy housing from the engine breather. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 15, 2010 Author Share Posted March 15, 2010 injector pump? any one happen to have a photo with an arrow? Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted March 15, 2010 Share Posted March 15, 2010 Where can I find the engine number on a 200tdi? I believe it is a discovery engine. Thanks in advance!! Horizontal face, front RHS of engine block just in front of and below number 1 injector. Matt Quote Link to comment Share on other sites More sharing options...
white90 Posted March 15, 2010 Share Posted March 15, 2010 Take a torch and look where we have pointed you it should be made up of Multiple dots. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 15, 2010 Author Share Posted March 15, 2010 I have just been out, and I think I have worked out where it is, and what could be the engine number... but cannot get to it its buried behind the air-con pump... Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2010 Share Posted March 15, 2010 in the yellow box, I'm sure this has been requested before. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 15, 2010 Share Posted March 15, 2010 You have air con? Is this perhaps of any use Ross? Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2010 Share Posted March 15, 2010 I have just been out, and I think I have worked out where it is, and what could be the engine number... but cannot get to it its buried behind the air-con pump... Disco 200Tdi serial starts with 12L then 5 more digits & possibly a letter. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 15, 2010 Author Share Posted March 15, 2010 Well I have been out again, and discovered a number in that area, although not that long... '52052A' is the number... id that right, or have I just got a part number I thought it probably had Western, but I searched and searched and couldn't find the answer! Retro - I have the pump there ready for an onboard air set-up. Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2010 Share Posted March 15, 2010 missing the 12L from the front of it but that partial serialnumber looks OK get your wire brush out tomorrow. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 15, 2010 Author Share Posted March 15, 2010 been out again and checked, there is a 12L in front of what i posted... just it is about 3/4" away! Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2010 Share Posted March 15, 2010 been out again and checked, there is a 12L in front of what i posted... just it is about 3/4" away! that's it then, if not on the V5 reg document, get the changes bit filled in & send it to DVLA to be updated. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 16, 2010 Author Share Posted March 16, 2010 I will check when i get it back from the dvla after changing owner. Quote Link to comment Share on other sites More sharing options...
western Posted March 16, 2010 Share Posted March 16, 2010 I would hope that Si had already taken care of the engine number update, but worth checking just in case he forgot. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 16, 2010 Author Share Posted March 16, 2010 I may be wrong, but I think it said unknown... Quote Link to comment Share on other sites More sharing options...
western Posted March 16, 2010 Share Posted March 16, 2010 I may be wrong, but I think it said unknown... not anymore Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 16, 2010 Author Share Posted March 16, 2010 I'm still waiting for the V5 back, so cannot check/change it yet Quote Link to comment Share on other sites More sharing options...
