Ian Warr Posted March 16, 2010 Share Posted March 16, 2010 Hi All, As an newbie to this site and Land Rover in general, I wondered if anyone could help me out? In January I purchased a L322 Range Rover 4.2 SC, MY2005. It's a truely wonderful vehicle and I find my self being impressed with it on a daily basis. My problem is this: Last Sunday, the engine warning light came on, and has remained on since. I have checked what I can (oil levels, water levels etc...) but can't find anything a miss. The engine sounds fine (no weird knocks, rattles or squeaks) and the power delivery is normal, but the light persists. I have it booked in at my local LR dealer this Friday for a diag. session, however I wondered if anyone could shed any light on this issue? One other point worth noting, is that the 'Low Coolant Level' warning appears on the info. centre. I have read somewhere that this was an issue with the sensor / float, not anything worse and LR knew about the problem and would replace under warranty- is this the case?? (the coolant level is fine, I have checked it on a number of occasions) Thanks in advance for your help Ian Quote Link to comment Share on other sites More sharing options...
Ian Warr Posted April 7, 2010 Author Share Posted April 7, 2010 And for anyone that's interested: Low Coolant Level - Faulty sensor, problem solved. Engine Warning light - Fuel Sensor Comm's Issue. System reset and all ok now. Quote Link to comment Share on other sites More sharing options...
