Badger90 Posted March 16, 2010 Share Posted March 16, 2010 hello people.. im a little confused this.. it is off my mums 90 300tdi crank timing sproket. that big gap by the key way.. is that ment to be there lol? cheers sam Quote Link to comment Share on other sites More sharing options...
Fatboy Posted March 16, 2010 Share Posted March 16, 2010 No. That indicates that the pully has been slack and has worn the keyway wider. Possibly because the bolt was not tight enough the last time the timing belt was replaced... Time for a new pulley and woodruff key for the shaft. You also need to have a good look at the shaft to make sure it is okay and the bolt and threads in the end. Quote Link to comment Share on other sites More sharing options...
Badger90 Posted March 17, 2010 Author Share Posted March 17, 2010 smashing.. just what i though.. my old grunter was insting on telling me that was how there ment to be.. i couldnt compear with anything. cheers sam Quote Link to comment Share on other sites More sharing options...
mmgemini Posted March 17, 2010 Share Posted March 17, 2010 Normal I was told. The bolt likes to undo it'self on the 300Tdi..... A vnew pulley and Woodruff key. Is the crank damaged ? Quote Link to comment Share on other sites More sharing options...
