tbeagley Posted March 18, 2010 Share Posted March 18, 2010 Hi all, new to the site & Landrovers. Have had my Defender 90 truck cab for about a month & had a vibration that was slowly getting worse. Tracked it to the rear UJ on the rear prop. I now have an oil leak from the front of the rear diff i assume caused by the vibrating UJ. Is there anything i can do about the leak? Replacement seal? Cheers, Terry. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 18, 2010 Share Posted March 18, 2010 This thread will help you. http://forums.lr4x4.com/index.php?showtopic=7903 Les. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted March 18, 2010 Share Posted March 18, 2010 Listen to GURU Les!! Get us a pick of the actual problem. It frames a better pic than words Quote Link to comment Share on other sites More sharing options...
tbeagley Posted March 18, 2010 Author Share Posted March 18, 2010 This thread will help you. http://forums.lr4x4.com/index.php?showtopic=7903 Les. Cheers Les! Excelent thread. Will do it at the weekend when i change all my UJ's. Terry Quote Link to comment Share on other sites More sharing options...
tbeagley Posted March 27, 2010 Author Share Posted March 27, 2010 Thought the pinion seal leaking was down to my rear u/j falling to bits as it happened at the same time, but when the hub seal started leaking as well i got suspicious of the axle breather & sure enough it was rusted solid. All done now, no leaks. Thanks for the help, Terry. Quote Link to comment Share on other sites More sharing options...
