muddy4x4xfar Posted March 18, 2010 Share Posted March 18, 2010 hey all . iv got a taping/rattling noise happening underneith my discovery 200tdi. it sounds to be on the drivers side. iv been under and really tried everything. but there doesnt seem to be any play in anything. it happens more over bumps. its not always there , so i think i could rule out the possibility of transmissions. any ideas anyone. cheers chris Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted March 18, 2010 Share Posted March 18, 2010 Possibly a UJ on the propshaft on the way out. To test it you must first unload it or you will never suspect anything. Park on the flat and chock the wheels and then make sure the handbrake is off. Get underneath and give the props a good wiggle. Any wear should become immediately apparent. Quote Link to comment Share on other sites More sharing options...
muddy4x4xfar Posted March 19, 2010 Author Share Posted March 19, 2010 cheers bud. theres also the odd smell of burning that happens every other day. and today the fuel light came on when there was half a tank of diesel. then when it went away the light went off. any ideas Quote Link to comment Share on other sites More sharing options...
Pinn76 Posted March 20, 2010 Share Posted March 20, 2010 Hi, I think that the two problems are not related. The rattling sounds like it could possibly be a UJ on one of the props on the way out. Mine has gone recently on the front but took a while to find this out as when underneath there was no play that I could feel, but decided to grease them anyway. Then noticed that there was no excess grease coming from one Spigot/Arm/Leg......thingy where the excess comes from.http://forums.lr4x4.com/public/style_emoticons/default/blink.gif On removal I found two were fine, one had no grease and rusted bearings and one had no bearings left at all and the outer shell was damaged prior to removing. Secondly the fuel light problem would suggest to me that the fuel level sender unit might be on the way out. I seem to remember reading on a forum somewhere about a wire on the bottom needing re-soldering. Hope this helps you. Bri Quote Link to comment Share on other sites More sharing options...
