GBMUD Posted March 18, 2010 Share Posted March 18, 2010 Checking and adjusting the rear wheel bearings earlier I discovered that the splines on the OSR halfshaft and drive flange are almost worn away. Is the halfshaft common to any other LRs? This 110 is late enough (2004) to have the Rover/Wolf/P38 type rear axle - just wondering if I might find a cheap SH shaft from something else - any clues as to the part numbers? Thanks Chris Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2010 Share Posted March 18, 2010 Sorry can't help, my Microcat only goes up to Sept 2002. but this might help Quote Link to comment Share on other sites More sharing options...
GBMUD Posted March 18, 2010 Author Share Posted March 18, 2010 Thanks Ralph. If it is only going to cost me £20 then I guess I will splash out on a new one. Chris Quote Link to comment Share on other sites More sharing options...
Aragorn Posted March 19, 2010 Share Posted March 19, 2010 That shaft linked is NOT a rover shaft, its a salisbury shaft. You want the normal rover axle shaft, TOB500020 Its the same as the shaft fitted to later 90's too, and is compatible with the mushroom shafts fitted to earlier 90/Discos Quote Link to comment Share on other sites More sharing options...
GBMUD Posted March 19, 2010 Author Share Posted March 19, 2010 That shaft linked is NOT a rover shaft, its a salisbury shaft. You want the normal rover axle shaft, TOB500020 Thanks. TOB500020 is apparently a long shaft, I need the short one which appears to be TOB500030, though it looks like I need to confirm that by chassis number. Now it looks like I will be spending more like £50. Chris Quote Link to comment Share on other sites More sharing options...
