black smoke
hi all
i have noticed the last few weeks that there has been a lot of black smoke coming from the exhaust but mostly when going up hill, but the last two days it seems to be constant as long as i am accelerating.
any ideas what could be the cause and possible cures
many thanks in advance
paul
someones secretly played with your fuel pump. personally i like it. black smoke is good :ph34r:. serious note, has anyone been under the bonnet? garage, mate?
it could be a blocked air filter. less air in the mix so less full combustion = exess diesel smoke. or a air hose collapsing under turbo load.
hi mate
nobody has messed about with the pump well not that i am aware of anyway,
and the air filter is brand new it was fitted last week to try a fix the problem,
does this meen that my pump is knackered.
paul
check the intake pipes, get a mate to rev it etc to see if you can see any pipes collapsing. on a 200tdi normally when in boost the top hose should feel like a bycycle tyre ie. hard to squeese but can a bit.
i dont know what youre engine is though (if its a petrol id be very very worried :rolleyes: )
