samd35
Roll cage advice
I am curently building a 100" comp safari racer and almost at the stage of fitting a roll cage! Can anyone recomend supliers and what spec is required as I am a bit confused about if I can use blue band or not? It will be used for AWDC events!
Thanks
Sam
Share this post
Link to post
Tech archive for you then under heading:
Protection
Rear cross member/winch carrier
Rollcage specs/Blue book
ALRC regs
Roll cages
Roll cage tube info
Welding a cage in a Defender
Defender storage lockers
Waxoyling
Front Diff guards
Strengthened cross member
110 double cab roll cage install
Defender wing bars
Northoffroad wing bars
Share this post
Link to post
Hi Sam, there's a few of us local to you (Nailsea) who race with AWDC, and I know of someone else in Clevedon building and 100" comp safari racer.
If you are looking to buy a cage, or have one fitted, rather then build from scratch I would look at....
http://www.whitbread-offroad.co.uk
http://www.northoffroad.co.uk
http://www.ppcages.com
If you're looking at building then there is a lot of good info in the tech archive as white90 says.
Share this post
Link to post
You may already be planning to do so, but if you are starting from scratch, I would recommend making the cage MSA spec (or better) from the outset. Far easier than having to modify the cage later on.
Share this post
Link to post
Thanks Mark,
yes i would be looking to get it fitted and I know someone else in clevedon who is also building one it might well be the same person! what material is your cage?
Sam
Share this post
Link to post
Seems we do know the same person. Small world eh. The current car we race is CDS, but the old one that was rolled and is being rebuild is/was blue band, both are acceptable for MSA spec cages.
Share this post
Link to post
