tbeagley Posted March 21, 2010 Author Share Posted March 21, 2010 Cheers Guys, i might just try one out as i have the front prop to do nexy weekend. Quote Link to comment Share on other sites More sharing options...
Giles tout terrain Posted March 21, 2010 Share Posted March 21, 2010 For £16 They are a absoulute bargain! i've enought to do with out wasting my life messing about with 2 spanners! The 3/8th one is perfect tool for the job on either battery or windy 3/8th gun makes a naff job simple Quote Link to comment Share on other sites More sharing options...
kevin Posted March 22, 2010 Share Posted March 22, 2010 Don't think about a short wobley extention with air gun they hurt when flying about under the car. proper tool = proper job = no blood on knuckles. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted March 22, 2010 Share Posted March 22, 2010 now to find one for cheap.....yorkshire ahoy. £16 is a bit pricy. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 23, 2010 Share Posted March 23, 2010 now to find one for cheap.....yorkshire ahoy. £16 is a bit pricy. I'm sure you'll find one in chocolate for cheaper..... Good tools do cost money. Quote Link to comment Share on other sites More sharing options...
cieranc Posted March 23, 2010 Share Posted March 23, 2010 3/8ths drive worth the money, yes. 1/2" drive not so. Although you could easily make a good tool with a cheap socket and extension, and the bench grinder. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 25, 2010 Share Posted March 25, 2010 Where is the best place to get one then? of the 3/8th variety. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 25, 2010 Share Posted March 25, 2010 I got mine from Diff-Lock. Bought a 1/2" one and wish I'd bought a 3/8" but hey never mind Quote Link to comment Share on other sites More sharing options...
LandyLee Posted March 25, 2010 Share Posted March 25, 2010 bought mine off foundry 4x4 , they`ve got both 3/8 and 1/2 drive versions. Great tool and very often borrowed by everyone Quote Link to comment Share on other sites More sharing options...
GL88 Posted March 26, 2010 Share Posted March 26, 2010 A good quality offset ring spanner works just as well. (Good quality so the wall thickness on the ring isn't too thick.) The trouble with the special tool is that it is a 'once in a blue moon' job and often not planned ahead so the alternative is that you buy the special tool on a 'just in case' basis and lose or lend it before it gets used. Quote Link to comment Share on other sites More sharing options...
kkk2 Posted March 26, 2010 Share Posted March 26, 2010 I vote yes as well what I see if there is any issue/repairs where wipping off the propshaft makes it easier with the tool no an issue, can I suggest you also buy a vehicle lift as this really makes taking off the propshafts really easy :D Quote Link to comment Share on other sites More sharing options...
Henry Webster Posted March 26, 2010 Share Posted March 26, 2010 The trouble with the special tool is that it is a 'once in a blue moon' job and often not planned ahead so the alternative is that you buy the special tool on a 'just in case' basis and lose or lend it before it gets used. I think that is the point - if its a 'once in a blue moon' job for you, then just use spanners its not that much hassle, but if you use your car hard like I do, or work on a few of them then it is worth while. That said I use a modded 9/16" 3/8" socket and a wobble bar. I probably have the propshafts on and off on average three or four times per year on the racer, notwithstanding working on the tow vehicle. Quote Link to comment Share on other sites More sharing options...
Mark Posted March 26, 2010 Share Posted March 26, 2010 Personally, I think it is worth every penny - I've had my 1/2" drive version for about 8 years, and I have long since forgotten how much it cost, and am just pleased by the quality and ease of use when I do use it. 1/2" Drive can be stuck on a rattle gun, so that gets my vote. Also worth mentioning that the propshaft tool and a rattle gun makes very quick work of taking a diff out of an axle... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 26, 2010 Share Posted March 26, 2010 What is the difference other than the drive size between the 3/8 and 1/2? is the 1/2" drive version more bulky or something? Quote Link to comment Share on other sites More sharing options...
white90 Posted March 26, 2010 Share Posted March 26, 2010 Yes but not that it matters as the important end is the same size. Quote Link to comment Share on other sites More sharing options...
JST Posted March 26, 2010 Share Posted March 26, 2010 i have a 1/2" one from Difflock and wouldnt be without it. with a windy gun or battery impact gun plus a 9/16th spanner it takes literally seconds to take the bolts out using it and haveing one wheel jacked up off the ground. Quote Link to comment Share on other sites More sharing options...
