Mr Bean Posted March 19, 2010 Share Posted March 19, 2010 Is it possible to change the front end on my 2002 TD4 to the newer style headlights and front bumper? Sorry if this has been answered before but i can't find it with the search function. Thanks Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted March 19, 2010 Author Share Posted March 19, 2010 I have found a bit more info this and it appears to be pretty DIY. Has anyone done this? Quote Link to comment Share on other sites More sharing options...
FreebieFreddy Posted March 20, 2010 Share Posted March 20, 2010 Hi, Yes I did the very first one in May 2004. It was on a X plate 3 door. The front is very easy and can be completed in 1/2 a day. Most if it is bolt off .... bolt on. The front panel needs to be cut and folded to allow the teardrop lamp. The connectors for the lamps are available from eBay. The back is a bit more of a challenge and took a whole day. I had to cut the inner black skin of plastic (with a Stanley Knife) to make it fit, The lower door mouldings needs the tailgate to be drilled. and the pillar lamps need the three hole fixing to be drilled and 'square' shaped. (the original three holes in the qtr panels are NOT the same) Good Luck Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted March 20, 2010 Author Share Posted March 20, 2010 I see you have the spot lights in your front bumper. Did you use any specific loom for these? Or did you add a button to the drivers console and just used a relay? Quote Link to comment Share on other sites More sharing options...
FreebieFreddy Posted March 21, 2010 Share Posted March 21, 2010 I see you have the spot lights in your front bumper. Did you use any specific loom for these? Or did you add a button to the drivers console and just used a relay? Hi, the bumper came with the fog lamp holes, so I had to fit them (beware the bezels are VERY VERY expensive - so get them second hand) I did fit the pod bumper lamps these are available on eBay. When wiring both fogs and pod lamps I used the correct instrument switches and relays with my own wiring loom. Have fun. Quote Link to comment Share on other sites More sharing options...
