manxrover Posted March 20, 2010 Share Posted March 20, 2010 Hi My RR DSE P38 1997 has for some reason lost half of the screen on the dashboard I can only read half of the mileage, does anyone know if it is a bulb that illuinates the screen or is it a LCD screen. if so can it be replaced, or how easy is a bulb change. Regards Brian Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted March 20, 2010 Share Posted March 20, 2010 There are several filament bulbs behind that screen. If one or more has failed you get the effect you have noted. http://www.rangerovers.net has a comprehensive section on the different bulbs used. Getting access to change the bulb is difficult enough to make it worthwhile changing all the general illumination bulbs while you are in there. Look under 'Instruments and Controls' Here HTH Quote Link to comment Share on other sites More sharing options...
