muppetslayer Posted March 20, 2010 Share Posted March 20, 2010 Hello everyone... I need some of your expert advice I have a 1987 90 turbo diesel with 149,000 miles on the clock. Yesterday and today it has developed a major vibration. What is causing it? The vibration occurs at speeds above 35mph and fairly quickly reaches its maximum and stays that way at all speeds The vibrations occurs in any gear When I change gear or let off the throttle the vibration stops to return as soon as the vehicle is under load. I have checked the prop shaft joints and they seem ok I have run the vehicle for a short while with diff lock and the vibration is similar. I ran the vehicle in low ratio in all gears and there was no vibration at all. I only went up to about 30mph. I hope this gives you enough information to maybe tell me what it is. Thanks Quote Link to comment Share on other sites More sharing options...
flatback90 Posted March 20, 2010 Share Posted March 20, 2010 have another look at your propshafts. handbrake off and out of gear shake the living ****e out of them! Quote Link to comment Share on other sites More sharing options...
crwoody Posted March 20, 2010 Share Posted March 20, 2010 I'll second the above, and if it is one of the props, (sounds likely,) avoid driving it until it's fixed as you will shake the guts out of the relevant diff or transfer box bearings & seals and give you a more costly repair bill. Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted March 20, 2010 Share Posted March 20, 2010 take one prop off (front) difflock in then try it, repeat for rear. also check tyres for nasty bulges and wheel nuts! Quote Link to comment Share on other sites More sharing options...
muppetslayer Posted March 21, 2010 Author Share Posted March 21, 2010 Thanks Chaps. I shall do that and let you know Quote Link to comment Share on other sites More sharing options...
