tbeagley Posted March 21, 2010 Share Posted March 21, 2010 Hi all, replaced pinion seal & u/j's on my rear prop yesterday (old u/j's in a bad way),much better now but still got a vibration that feels like something out of balance. Marked everything up before the strip down so as it went back the same. Just wanted to check how prop should be aligned. Should yokes be at the same angle, or 90 degrees to each other, Cheers, Terry. Quote Link to comment Share on other sites More sharing options...
western Posted March 21, 2010 Share Posted March 21, 2010 Rear prop yokes should be inline/phase front prop yokes out of line/out of phase by approx 30 degrees.should be engraved arrows on both the propshaft & yoke to align when refitting. Quote Link to comment Share on other sites More sharing options...
tbeagley Posted March 21, 2010 Author Share Posted March 21, 2010 Rear prop yokes should be inline/phase front prop yokes out of line/out of phase by approx 30 degrees.should be engraved arrows on both the propshaft & yoke to align when refitting. Thanks! will check Tomorrow, Terry. Quote Link to comment Share on other sites More sharing options...
tbeagley Posted March 26, 2010 Author Share Posted March 26, 2010 Rear prop yokes should be inline/phase front prop yokes out of line/out of phase by approx 30 degrees.should be engraved arrows on both the propshaft & yoke to align when refitting. Prop/Yokes seem to be lined up ok but still got quite a bad vibration at about 45mph. Would the grease nipples on the u/j's put it out of balance as i didn't mark them up when i stripped the prop & can't be sure they are in the same place. Oil leaking from pinnion seal turned out to be a blocked breather. The new seal as well as the hub seal started leaking again & on inspection the breather was blocked solid. Cheers, Terry. Quote Link to comment Share on other sites More sharing options...
