headdamage Posted March 22, 2010 Share Posted March 22, 2010 How important is it that you follow this caution note in the 200tdi book? \ CAUTION: If the original skew gear and camshaft are to be re-used, they must be fitted so that the teeth on each, mesh in the original position. If either the skew gear or the camshaft are renewed, the mating component must also be renewed. I have, of course, lost track of the relation between the skew gear and camshaft when taking apart my 200tdi for rebuilding. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 22, 2010 Share Posted March 22, 2010 I take it you mean the camshaft to oil pump/vaccuum, pump drive? It would be difficult to mesh them as original, so as long as all the parts are in good order - I personally wouldn't/don't do it. Normal wear would be uniform, so I can't see that there's any risk involved. Les. Quote Link to comment Share on other sites More sharing options...
western Posted March 22, 2010 Share Posted March 22, 2010 had to change my cam a while ago, the skew shaft hasn't caused any problem by not having it's orignal cam fitted. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted March 23, 2010 Share Posted March 23, 2010 I didnt bother meshing them the same and it hasnt caused problems so far. Quote Link to comment Share on other sites More sharing options...
