love2learn Posted March 22, 2010 Share Posted March 22, 2010 theres a strange star shaped nut holding the calipers on my 110? noone over here seems to know what they are called or where to find em? anyone? Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted March 22, 2010 Share Posted March 22, 2010 theres a strange star shaped nut holding the calipers on my 110? noone over here seems to know what they are called or where to find em? anyone? It is a normal bolt (M8 I think) with a 12 point head on it, you can use a 12 point socket or (if you can get one on) the ring end of a 13mm spanner. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 22, 2010 Share Posted March 22, 2010 yeh, 12 point head. socket is the easiest. Not much point trying a spanner in there, would be there all day! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 22, 2010 Share Posted March 22, 2010 The tool you need is known as a spline bit (internal), or spline socket. It's basically a 12-point socket. Les. Quote Link to comment Share on other sites More sharing options...
M&S Posted March 22, 2010 Share Posted March 22, 2010 Yup, do a search for bi-hex sockets. Cromwells and such like stock them and can be purchased individually. As said above though, a ring spanner should fit. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted March 22, 2010 Share Posted March 22, 2010 There are actually three different fitments that all look very similar. Bi-Hex or double hex is basically two normal hex heads overlayed on top of each other to give 12 points. You also get Triple Square or XZN, which looks similar, but has three squares overlayed, giving 90degree points rather than 120 degree as found on bi-hex, then you get Spline Drive, which is somewhere between the two, but again "incompatible". In reality they're all pretty similar, and you'll probably find they'll interchange to some extents, but using a bi-hex socket on a XZN thats very tight for example could make the difference between it coming out, and stripping it. The caliper bolts will most likely be bi-hex though, meaning a normal 12 point hex socket or a ring spanner will undo them, as said. Quote Link to comment Share on other sites More sharing options...
cieranc Posted March 23, 2010 Share Posted March 23, 2010 I found mine were siezed in and the heads badly corroded. I had to use a drift to bray a tight fitting spanner on to them to crack them off. Then once turning, bray the spanner back off again. Then fit new bolts. Actually, I might be thinking of the swivel bolts Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 23, 2010 Share Posted March 23, 2010 I need one new caliper bolt, I half rounded one off at the weekend. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 23, 2010 Share Posted March 23, 2010 Ross there are two types Imperial and metric make sure you get the correct one. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted March 23, 2010 Share Posted March 23, 2010 As Cieranc^^^^^becareful which of the bolts you use. One is much thicker whiles the other is much smaller. It reminds me of the lock nuts on the TREs. Any interchange will render the threads useless.... I did destroy my caliper threads when I interchanged the bolts.... check these out.. For my TD5 99my I used the one on the left!!!! Quote Link to comment Share on other sites More sharing options...
LandyLee Posted March 23, 2010 Share Posted March 23, 2010 britpart selll the bolts singly if needed and they come with thread lock paste already on em,,, draper expert 13mm 12 pt socket takes em off. if they are rusty then a 1/2" 12pt socket tapped on will still remove the bolts. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 24, 2010 Share Posted March 24, 2010 Guess I will need an imperial one, as its a 1984 axle? Quote Link to comment Share on other sites More sharing options...
