reb78 Posted March 22, 2010 Share Posted March 22, 2010 I have a hole in the chassis rail that sits centrally behind the plate of the gearbox crossmember. If is in the nearside chassis rail and is about 1.5 - 2 inches by about 2 inches from memory. Given how tight the crossmember is to get between those rails and the strength i presume it provides to that section when it is bolted up, would you weld that hole up or leave it and waxoyl as is? Obviously if i am welding it up, i want to do it before i waxoyl. Perhaps i should stop being lazy and just weld it! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 22, 2010 Share Posted March 22, 2010 You will have to cut out the rust and weld a plate flush - rather than on top, as the crossmember may not go back in because of the reduced distance. It's very common for the chassis to rust there. I've done a few of the same. Les. Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 22, 2010 Author Share Posted March 22, 2010 I was thinking of tacking a small plate across each corner of the hole inside the chassis so that the plate i cut to sit in the hole (rather than on top) can be clamped in place flush and then welded (think that makes sense). I need to do this before i can finish rustproofing the chassis, but i have little motivation for either job at the moment!! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 22, 2010 Share Posted March 22, 2010 That's quite a good plan ^^^ So is using a magnetic spiritlevel (if you need the length)/magnetic welders clamp to hold it in place while you tack Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted March 22, 2010 Share Posted March 22, 2010 i welded my one up then i did the gearbox cut the rust out and welded a plate in the hole well worth is hole only get bigger Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 23, 2010 Share Posted March 23, 2010 That's quite a good plan ^^^ So is using a magnetic spiritlevel (if you need the length)/magnetic welders clamp to hold it in place while you tack I often just tack a bit of scrap on to the patch, to use as a handle for positioning the patch in the hole. grinding the tacks off is no hassle. Quote Link to comment Share on other sites More sharing options...
