Christian Eilersen Posted March 23, 2010 Share Posted March 23, 2010 Hi Forum, Like so many Defender owners, I am tired of changing/painting the hinges on my Defender once every few months to keep the rust away.. - just to discover the rust is running off the hinges, seconds after I am done.. Just came across these britpar aluminium hinges at Paddock's http://www.paddockspares.com/pp/DEFENDER/Body_and_Panels/Aluminium_Door_Hinges_with_stainless_steel_hinge_pins_-_Set_of_4.html Have anyone tried these - and are they any good? It still have a steel hinge pin.. how much rust can that produce :-) kind regards, Christian Quote Link to comment Share on other sites More sharing options...
Maverik Posted March 23, 2010 Share Posted March 23, 2010 Read through the link below, some chappy has i think. http://forums.lr4x4.com/index.php?showtopic=54103 Quote Link to comment Share on other sites More sharing options...
SteveG Posted March 23, 2010 Share Posted March 23, 2010 you could also buy the later ones that don't rust for a lot less. Quote Link to comment Share on other sites More sharing options...
Christian Eilersen Posted March 23, 2010 Author Share Posted March 23, 2010 This doesn't seem to refer to the aluminium hinges from Paddock? The Cryotek ones are not really comparable, since they cost 3 times as much.. :-) Read through the link below, some chappy has i think. http://forums.lr4x4.com/index.php?showtopic=54103 Quote Link to comment Share on other sites More sharing options...
Christian Eilersen Posted March 23, 2010 Author Share Posted March 23, 2010 I actually replaced the original cast iron ones with TD5-hinges. Was just wondering if the aluminium hinges were even better than the TD5-version? you could also buy the later ones that don't rust for a lot less. Quote Link to comment Share on other sites More sharing options...
