Allantrailrider Posted March 23, 2010 Share Posted March 23, 2010 Recently fitted new front prop but now noticed a rumbling noise when taking foot off the gas - any ideas?? Also rear pads don't seem to be scrubbing inside of rear discs but had them off last year to cleam etc and re-bled Are these common issues its a 1998 Def 90 300tdi Quote Link to comment Share on other sites More sharing options...
KKMobile Posted March 23, 2010 Share Posted March 23, 2010 Is the brake pedal spongy?? If so it's probably the rear wheel bearing rumbling?? Need adjusting or replacing. Then your brakes will be back to normal to. Quote Link to comment Share on other sites More sharing options...
Allantrailrider Posted March 24, 2010 Author Share Posted March 24, 2010 No the brakes are not spongy just wondered if there may be some issue with front rear bias - bled all round last year with pressurised bleed kit - all fluid clear and no air bubbles, replaced rear pipes and all bleed nipples. Not fitted rear disc guard since thats how i noticed the inner rear disc not scrubbing clean. Quote Link to comment Share on other sites More sharing options...
