pugrocket Posted March 23, 2010 Share Posted March 23, 2010 Hi guys. I have taken the front hub off today to fix a leaky seal, bit of a nightmare mind. anyway when I took the caliper off, brake fluid started coming out. Is this normal or do I need to rebuild the caliper? I'm not so sure now that the hub was leaking as it could have been brake fluid. Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2010 Share Posted March 23, 2010 where was the caliper leaking from ? one of the piston seals or the pipe or it's connection Quote Link to comment Share on other sites More sharing options...
pugrocket Posted March 23, 2010 Author Share Posted March 23, 2010 where was the caliper leaking from ? one of the piston seals or the pipe or it's connection When i prised the caliper apart in to 2 pieces Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2010 Share Posted March 23, 2010 When i prised the caliper apart in to 2 pieces Ah, not the best or easiest way to remove a caliper, you'll need the small O ring seals to rejoin it before refit. better to slacken the top swivel pin bolts or take them out 1 at a time, get the flexi hose bracket out of the way & remove the 2 bolts that hold the caliper to the swivel housing, then tie it up with a ty-wrap or string. Quote Link to comment Share on other sites More sharing options...
pugrocket Posted March 23, 2010 Author Share Posted March 23, 2010 Ah, not the best or easiest way to remove a caliper, you'll need the small O ring seals to rejoin it before refit. better to slacken the top swivel pin bolts or take them out 1 at a time, get the flexi hose bracket out of the way & remove the 2 bolts that hold the caliper to the swivel housing, then tie it up with a ty-wrap or string. would it be best to buy a new caliper? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 23, 2010 Share Posted March 23, 2010 ie, don't take it apart Mo Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2010 Share Posted March 23, 2010 would it be best to buy a new caliper? get 8 of these Seal fluid channel 17H8764L [4 for each caliper] you can replace the seals & rejoin the caliper halfs & refit.no need to buy a complete new caliper. if the piston seals are leaking they can be changed too AEU2539 you'd need 2 of those to reseal both sets of pistons. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted March 23, 2010 Share Posted March 23, 2010 would it be best to buy a new caliper? Send a pic for better diagnose. Response is much better that way Quote Link to comment Share on other sites More sharing options...
white90 Posted March 23, 2010 Share Posted March 23, 2010 Try the Tech archive before commencing work you are unsure of if this isn't a wind up Quote Link to comment Share on other sites More sharing options...
pugrocket Posted March 24, 2010 Author Share Posted March 24, 2010 get 8 of these Seal fluid channel 17H8764L [4 for each caliper] you can replace the seals & rejoin the caliper halfs & refit.no need to buy a complete new caliper. if the piston seals are leaking they can be changed too AEU2539 you'd need 2 of those to reseal both sets of pistons. where do I get those things from? And if I fit that stuff will it just be a case of refitting the caliper or would I need a caliper rebuild kit too or is what you are telling me to get the same as a rebuild kit? Thanks Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted March 24, 2010 Share Posted March 24, 2010 Same as the re-build kit, but separate.. Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2010 Share Posted March 24, 2010 LR main dealer or any of the independent LR parts supplier should be able to source them, a caliper rebuild kit is just a pack of piston seals, so whichever you choose will get the same result. AEU2359 caliper piston seal kit Quote Link to comment Share on other sites More sharing options...
