nickwilliams Posted March 23, 2010 Share Posted March 23, 2010 I'm in the early stages of a chassis rebuild on my 90. I'm taking a 1990 19J vehicle and putting a galv chassis with a 300tdi engine and R380 gearbox on it. I've obtained a 300tdi engine and I'm trying to decide what I should do to it before putting it into the vehicle. Changing the cam belt is one obvious item, and I'm wondering if a new clutch plate is also desirable. The one that's on it is 8mm thick side to side. Does that sound very worn? Does anyone have a new one they can measure for me? The current part is stamped 'Valeo'. While the clutch plate is not itself very expensive in the overall scheme of things, this project is already turning into a fairly serious money pit and there are better uses for the money if a new plate is not required. Thanks Nick. Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2010 Share Posted March 23, 2010 I would fit a complete new clutch -- friction plate,pressure cover,release bearing, re-inforce the operating fork around the ball socket & anchor the slave cylinder pushrod to the fork too [see picture below] last thing you want is a gearbox/engine split to do a clutch change. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted March 24, 2010 Share Posted March 24, 2010 i agree! Its about 60quid for a clutch kit, so you may as well do it when its apart, and fit the "hd" version from the 130 when your there. Quote Link to comment Share on other sites More sharing options...
adam300Tdi90 Posted March 24, 2010 Share Posted March 24, 2010 Also, and I know from experience that this seems to be OTT, but do the rear crank oil seal too! I've just put mine together and found that the seal is leaking, took a day to take it apart again to fix the seal... Quote Link to comment Share on other sites More sharing options...
