darzo Posted March 25, 2010 Share Posted March 25, 2010 Good morning, I previously posted about my Satnav not working and someone said to remove the fuse, my ever so helpful partner decided he would disconnect the battery instead so now I have to insert a code. My manual says it is on the security card which I have, there is a serial number but no code grrrrr! The serial number is E4765HJO45022433, however when searching for the code online it says the code should start with RG. Any advice would be great please as silence is certainly not golden! Quote Link to comment Share on other sites More sharing options...
mudcrawler Posted March 25, 2010 Share Posted March 25, 2010 Quickest way to get the code is to ask your nearest Land Rover dealer. They can look it up for you! Some will charge for the privilege, others won't so phone a few of them if the first one tries to charge you! Quote Link to comment Share on other sites More sharing options...
td4s Posted March 29, 2010 Share Posted March 29, 2010 Quickest way to get the code is to ask your nearest Land Rover dealer. They can look it up for you! Some will charge for the privilege, others won't so phone a few of them if the first one tries to charge you! Hi there, You tried: http://www.radio-code.co.uk/?gclid=CJPmxd_I3qACFZpc4wodWBbCBg As you have the reference number you will get it in seconds I think for a small fee. Brother did not have the code on this Radio in his Porsche 996 and it helped! Hope it helps. regards Nick Quote Link to comment Share on other sites More sharing options...
