sharpy Posted March 26, 2010 Share Posted March 26, 2010 Hi All, With summer approaching I decided to spruce up my truck a little, so I have taken off my wheel spats for a quick coat of satin black. After waiting until her indoors was out I popped them in the shower for a wash and gave them a scrub with a green plastic scourer, let them dry overnight and sprayed them, my problem is they dry like they have been bleached by the sun, all white and patchy, 4 coats later they are just getting worse, any ideas? I am using simonez acrylic satin black, im not new to spraying bits and bobs so i think i have done all i should, i didnt want to use undercoat as i dont want to loose the texture that is in the plastic. Cheers Paul Quote Link to comment Share on other sites More sharing options...
rovernut Posted March 26, 2010 Share Posted March 26, 2010 Hi All, With summer approaching I decided to spruce up my truck a little, so I have taken off my wheel spats for a quick coat of satin black. After waiting until her indoors was out I popped them in the shower for a wash and gave them a scrub with a green plastic scourer, let them dry overnight and sprayed them, my problem is they dry like they have been bleached by the sun, all white and patchy, 4 coats later they are just getting worse, any ideas? I am using simonez acrylic satin black, im not new to spraying bits and bobs so i think i have done all i should, i didnt want to use undercoat as i dont want to loose the texture that is in the plastic. Cheers Paul Hi Paul, Is this the first time you have sprayed them ? There is probably a build up of silicone (back to black) etc; that will not be removed by scrubbing with soap & water. You may have to put on a barrier coat of an undercoat containing a plasticiser of some kind. Also clean them with panel wipe. Unfortunately you may well loose the textured finish. Quote Link to comment Share on other sites More sharing options...
western Posted March 29, 2010 Share Posted March 29, 2010 Strip the paint off & work some black boot polish in & then buff them up. if you really want to paint them you'll need some plastic primer as mentioned above. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 29, 2010 Share Posted March 29, 2010 related, but still sorry to highjack... what can I use to strip the paint off my arches? Quote Link to comment Share on other sites More sharing options...
kingrat Posted March 29, 2010 Share Posted March 29, 2010 I'd get some wire wool and a tub of elbow grease. Especially if you want to keep the texture. Most thinners and paint strippers would destroy the plastic I expect. Quote Link to comment Share on other sites More sharing options...
jonost24 Posted March 29, 2010 Share Posted March 29, 2010 Try some black plastikote Quote Link to comment Share on other sites More sharing options...
sharpy Posted April 1, 2010 Author Share Posted April 1, 2010 related, but still sorry to highjack... what can I use to strip the paint off my arches? Hi, I have found some paintstripper that doesn't seem to affect plastic, it is from Wickes and is called "Great Strip" Made by "De-Solv-it", I have used it in the past on Airsoft rifles, which I think are an ABS plastic and also last night I used it on my wing top vents with no ill side affects, obviously with anything try a little piece that you can't see, the instructions don't say you can use it on plastic but i have with great sucsess. Cheers Paul Quote Link to comment Share on other sites More sharing options...
