nightrider Posted March 28, 2010 Share Posted March 28, 2010 Hi which way do you turn the screw on the back of a 300tdi injector pump to weaken the mixture. also i was told if you take the 4 screws out of the plate on top of the injector pump there is a wheel under it which you can turn to give it a bit more power which way do you turn this and how much do you turn it. thanks for any help you Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 28, 2010 Share Posted March 28, 2010 Have a read here: http://forums.lr4x4.com/index.php?showtopic=31 and here: http://www.lro.com/forum/viewtopic.php?t=44813 to understand it a bit better and do the opposite since these threads are all about increasing performance and it sounds like you want to back it off a bit. The alterations you mention require turning the diaphragm and/or starwheel and/or max fuel screw anticlockwise. I would start with the cone on the diaphragm and the starwheel and leave the max fuel screw alone for now and see if that has the desired effect. Quote Link to comment Share on other sites More sharing options...
nightrider Posted March 28, 2010 Author Share Posted March 28, 2010 Have a read here: http://forums.lr4x4.com/index.php?showtopic=31 and here: http://www.lro.com/forum/viewtopic.php?t=44813 to understand it a bit better and do the opposite since these threads are all about increasing performance and it sounds like you want to back it off a bit. The alterations you mention require turning the diaphragm and/or starwheel and/or max fuel screw anticlockwise. I would start with the cone on the diaphragm and the starwheel and leave the max fuel screw alone for now and see if that has the desired effect. I altered the fuel screw on the back of the pump ages ago and couldnt remember which way i turned it to up fuel. It smokes quite a bit and mot is comeing up so need to sort it Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 28, 2010 Share Posted March 28, 2010 Ah, Anticlockwise then. Out to decrease, in to increase. Quote Link to comment Share on other sites More sharing options...
