Spearos Posted March 28, 2010 Share Posted March 28, 2010 Need to replace the alternator on the above vehicle. It is a factory fitted V8 and was originally fitted with Air-con (if that makes any difference?) The alternator has a stud fitting and uses a V belt. Quote Link to comment Share on other sites More sharing options...
western Posted March 29, 2010 Share Posted March 29, 2010 Which side of the engine/vehicle is the Alternator fitted too ? as there are left & right fit alternators available. Quote Link to comment Share on other sites More sharing options...
Spearos Posted March 29, 2010 Author Share Posted March 29, 2010 Which side of the engine/vehicle is the Alternator fitted too ? as there are left & right fit alternators available. It's on the passenger side and takes drive from the PAS pump. Cheers Quote Link to comment Share on other sites More sharing options...
western Posted March 29, 2010 Share Posted March 29, 2010 Have a look at Pages 355 to 359 inclusive dependind on which amperage & whether ignition or battery sensed, I suspect it'll be one of the 65amp alternator you need, possibly on page 358. hth. Quote Link to comment Share on other sites More sharing options...
