RSAstan Posted March 29, 2010 Share Posted March 29, 2010 Hello all , Have had to abandon the OEM -18" -255 X 55 tyre's on my Disco TDV 6 in order to be able to drive in real african off road and due to supply & size limitations have just bought set 18" - 265 X65 BFG A/T. Thanks for feedback initially received re "can fit Disco 3" -helped in the choice , next step help/ advise required > With the greater Diameter of the 265 X 65 on the OEM wheel Rim, what will be required to be done if any on ECM's etc for ABS / Gearing -Tiptronic settings ??? From a table i found on the web , the wheel Diameter change will give a 5% discrepancy on the speedo so assume that can also be reprogramed in the speed processor ???-any one with prior experience - Disco 3 Technical advise ???. Thanks Stan Living life =having an L.R Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 29, 2010 Share Posted March 29, 2010 I doubt you can do anything unless you are an electronics genius, and in any case it really isn't needed - things like ABS work off relative wheel speeds so a skid is still a skid - the absolute speed is irrelevant. You're a braver man than me taking a D3 through the wilds of Africa Quote Link to comment Share on other sites More sharing options...
