Maverik Posted March 31, 2010 Share Posted March 31, 2010 Is it worth me spending £70 on a OEM water pump or go for AN OTHER for £35? Who makes reliable water pumps? Quote Link to comment Share on other sites More sharing options...
fender1234 Posted March 31, 2010 Share Posted March 31, 2010 I would say get the airtex one as thats what i did and its still in mint condition after 2 years, which is more than can be said for alot of the cheap ones. Quote Link to comment Share on other sites More sharing options...
trt1617 Posted March 31, 2010 Share Posted March 31, 2010 i have put 3 water pumps on my 300tdi in the last year 1st one i put on when the p gasket went and i thought it would be a good idea to change it,this fell apart and trashed the new belt id put on phoned up the supplier and they sent another one and a new belt free of charge five months later i noticed a puddle of water under my truck sure enough water pump leaking so took the belt off to check it and the bearings had failed so caught it before it exploded. phoned them again and they said that they would supply me a airtex one if i payed the difference in price they would get it to me next day free of charge, and touch wood its ok so far so from personal experience i would go with an airtex one Quote Link to comment Share on other sites More sharing options...
LandyLee Posted March 31, 2010 Share Posted March 31, 2010 Run it at the correct tension , with the correct amount of proper anti frezze and with a fan on it that is in balance and you are half ways home. These are the usual probs we get with premature failure of water pumps fitted by others Quote Link to comment Share on other sites More sharing options...
Rob110 Posted April 1, 2010 Share Posted April 1, 2010 Hi I fitted a airtex water pump the other day and noticed that the impellor was made from pressed steel and the one i took off (the original) was made of cast alu. Can anyone confirm if this is correct, or have paddocks swapped the boxes??? Cheers Quote Link to comment Share on other sites More sharing options...
sgnas Posted April 1, 2010 Share Posted April 1, 2010 i have put 3 water pumps on my 300tdi in the last year 1st one i put on when the p gasket went and i thought it would be a good idea to change it,this fell apart and trashed the new belt id put on phoned up the supplier and they sent another one and a new belt free of charge five months later i noticed a puddle of water under my truck sure enough water pump leaking so took the belt off to check it and the bearings had failed so caught it before it exploded. phoned them again and they said that they would supply me a airtex one if i payed the difference in price they would get it to me next day free of charge, and touch wood its ok so far so from personal experience i would go with an airtex one I had almost identical experience with 2 pattern pumps on a 300tdi. Fitted an Airtex one and (touch wood) all ok now. One of the patterns lasted <3000miles! Pulley, belt tensioner etc all confirmed ok. Airtex IS now oem for landrover on the 300tdi, I got mine from main dealer in a LR box. I don't have it in front of me but I'm fairly certain it has Airtex logo on the casting. Quote Link to comment Share on other sites More sharing options...
Maverik Posted April 1, 2010 Author Share Posted April 1, 2010 Thanks for the input, I think I'll do the Airtex investment option! Quote Link to comment Share on other sites More sharing options...
JonR Posted May 3, 2010 Share Posted May 3, 2010 I'm in need of a water pump for my 200tdi as well. Could someone be kind enough to point me in the direction of an Airtex stockist. Thanks in advance. Jon. Quote Link to comment Share on other sites More sharing options...
