ThreePointFive Posted April 2, 2010 Share Posted April 2, 2010 Hi all, the wash wipe pump for the front of my 05 plate TD4 has packed in. Don't know anything about these, I know they're on the o/s front wing but how do you access it? Appears to be a bumper-off job. Anyone heard of this failing before? The car has under 20,000 on it, bit surprised really... I am hoping it's just a loose or corroded wire, not a new pump. Any help gratefully received. Quote Link to comment Share on other sites More sharing options...
FreebieFreddy Posted April 2, 2010 Share Posted April 2, 2010 Hi all, the wash wipe pump for the front of my 05 plate TD4 has packed in. Don't know anything about these, I know they're on the o/s front wing but how do you access it? Appears to be a bumper-off job. Anyone heard of this failing before? The car has under 20,000 on it, bit surprised really... I am hoping it's just a loose or corroded wire, not a new pump. Any help gratefully received. .... yes I am afraid it is bumper off time. ...... check the fuse first thou. the bumper comes off quite easy, but remember the two (one either side) nuts that hold the bumper to the wings, which are accessed through the inner wing plate (that gives access to front indicator bulb) ;-) Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted April 6, 2010 Author Share Posted April 6, 2010 Thanks for the reply. Looks like we won't be doing the work then, it's a newish car and its not quite the same as tinkering with a defender on your driveway! Cheers Quote Link to comment Share on other sites More sharing options...
