gelf Posted May 6, 2006 Share Posted May 6, 2006 any ideas why when i put the hazzard lights on only 2 of them work[passenger side]........... indicators work ok Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 6, 2006 Share Posted May 6, 2006 Sounds like the switch itself is dead. the switch keeps both LH and RH circuits "separate" so that when, for example, you indicate left, the RH side doesn't flash with it... make sense? so when you turn the hazzards on, it connects both LH & RH together to make them flash simultainously (sp! ) if only one side is flashing when you turn them on, then it's got to be the switch. Quote Link to comment Share on other sites More sharing options...
mattD110td5x Posted May 7, 2006 Share Posted May 7, 2006 yep, sounds like the switch, I had a similar problem. should be easy to check with a multimeter/pilot light. the switch is actually 2 switches in one; the bottom 3 contacts supply power back to the flasher relay and the top 4 are 2 for the LHS and 2 for the RHS. There is a "known issue" similar to the headlight switch where the nylon bits melt, due to towing trailers with dodgey electrics and can cause strange operation. !warning! the LR part has some cost issues If you are going to use a non-LR part then consider dissassembling the old switch (!warning! flying parts - choking hazard) taking the good bits from the el-cheepo switch and reassemble. ttfn, Matthew Quote Link to comment Share on other sites More sharing options...
simonr Posted May 7, 2006 Share Posted May 7, 2006 Switch - absolutly no doubt. Sadly, they ain't cheap! Si Quote Link to comment Share on other sites More sharing options...
