welling4x4 Posted April 2, 2010 Share Posted April 2, 2010 Can any one HELP. I have a range rover with a factory fitted VM engine. on road it goes very well off road BUT off road the engine won't pull the skin off a rice pudding. I have changed the fuel lift pump with a new original one. I changed the fuel filter. fitted new pipe work from tank to lift pump & now I am @ a loss & am calling on the more experience off roaders for help. THANKS. Quote Link to comment Share on other sites More sharing options...
taurion Posted April 6, 2010 Share Posted April 6, 2010 I presume you want a bit more torque at low engine speed to solve your off road problem. My RR works on the farm and tows a 3.5t trailer. To improve the general drivability I have tweeked the fuel pump. 3 turns on the knurled nut in the fuel pump under the turbo diapragm brings in max turbo boost at 1500rpm. But.... Max boost pressure 1 bar , max EGT 600- 700°C, and keep an eye on cylinder head temp, if not a short life. It is the same adjustment that can be done to the 200 /300tdi because they all have the Bosch VE fuel pump. Quote Link to comment Share on other sites More sharing options...
welling4x4 Posted April 7, 2010 Author Share Posted April 7, 2010 I presume you want a bit more torque at low engine speed to solve your off road problem. My RR works on the farm and tows a 3.5t trailer. To improve the general drivability I have tweeked the fuel pump. 3 turns on the knurled nut in the fuel pump under the turbo diapragm brings in max turbo boost at 1500rpm. But.... Max boost pressure 1 bar , max EGT 600- 700°C, and keep an eye on cylinder head temp, if not a short life. It is the same adjustment that can be done to the 200 /300tdi because they all have the Bosch VE fuel pump. Thanks very much. I'll have a l@@k to see whats what. Quote Link to comment Share on other sites More sharing options...
