lapperz Posted April 3, 2010 Share Posted April 3, 2010 hi ive noticed oil splating on the rear wheel, there isnt a rubber centre cap on, is this why, or is there a seal or something thats gone, cheers Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 3, 2010 Share Posted April 3, 2010 If it's on the outside of the wheel, then it's either the hub cap missing (if there's supposed to be one on it), or the drive member gasket. Les. Quote Link to comment Share on other sites More sharing options...
Litch Posted April 3, 2010 Share Posted April 3, 2010 There should be an oil-cap fitted to the end of the drive-flange (look at the other wheels to see if they have them or if they have gone missing as well).Fit a new one (not expensive at 99P brand new) and all should be well. Quote Link to comment Share on other sites More sharing options...
lapperz Posted April 3, 2010 Author Share Posted April 3, 2010 There should be an oil-cap fitted to the end of the drive-flange (look at the other wheels to see if they have them or if they have gone missing as well).Fit a new one (not expensive at 99P brand new) and all should be well. think its the hub cap Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2010 Share Posted April 3, 2010 think its the hub cap you need one of these FRC4377 drop it in hot water fora few minutes, dry it, put a splash of EP90 in & fit to hub driving member, it'll grip tight as it cools. Quote Link to comment Share on other sites More sharing options...
RILEY Posted April 4, 2010 Share Posted April 4, 2010 And check your axle breather Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted April 5, 2010 Share Posted April 5, 2010 Got the same thing with mine. Like Riley says check the breather Quote Link to comment Share on other sites More sharing options...
lapperz Posted April 6, 2010 Author Share Posted April 6, 2010 Got the same thing with mine. Like Riley says check the breather check the breather for what Quote Link to comment Share on other sites More sharing options...
western Posted April 6, 2010 Share Posted April 6, 2010 check the breather for what that it's clear, not blocked, it allows the axle to breath & lets excess pressure escape. Quote Link to comment Share on other sites More sharing options...
