henrycrabbe Posted April 3, 2010 Share Posted April 3, 2010 Q - can anyone tell me the wheel stud thread type and size used on earlier series vehicles? I've managed to get hold of some nice Wolfrace alloys but they need special sleeve-nuts. I have some metric nuts that fit later series and coil axles, but before I go and swap hubs etc, I'd wondered if you could get imperial nuts to fit the axles I already have? Ta. Steve. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted April 3, 2010 Share Posted April 3, 2010 In a word, unlikely, unless you have some specially made. The earlier thread was 9/16" BSF (British Standard Fine), the later ones will be 16mm. Quote Link to comment Share on other sites More sharing options...
steve b Posted April 3, 2010 Share Posted April 3, 2010 As David says , 9/16" BSF if they are screwed in and staked on back of hub, M16 fine ones are knock in type hth Steveb Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted April 3, 2010 Share Posted April 3, 2010 There were also some late 2a with knock in 9/16"BSF studs that used single ended nuts, just to confuse matters. Quote Link to comment Share on other sites More sharing options...
steve b Posted April 3, 2010 Share Posted April 3, 2010 Yep you are right there Phil I'd forgotten about them 9/16" = 14 mm and obviously M16 = 16mm dia for a quick check. The threaded and staked studs don't like wheels that are not a close fit on the hub dia and invariably work loose cheers Steveb Quote Link to comment Share on other sites More sharing options...
henrycrabbe Posted April 3, 2010 Author Share Posted April 3, 2010 Cheers guys, it definitely has 9/16" studs then. From a quick check on the web, it seems I'm going to have to change to M16 studs if I want to use these wheels, which leads to the question of how best to do it? I suppose I could swap the hubs over? Will this pose any problems with bearings or seals between earlier ('68) stub axles and later metric hubs, or should I just knock out the old studs, drill out the holes and replace with new studs? Thanks again, Steve Quote Link to comment Share on other sites More sharing options...
