Mo Murphy Posted April 3, 2010 Share Posted April 3, 2010 Evening all, A couple of questions for those of you that have done this conversion. What bottom hose did you use ? The coolant inlet on the engine is a good bit lower than the rad so the hose is close to kinking. Secondly, regarding the oil cooler lines, do standard Defender items do the trick, are they long enough ? TIA Mo Quote Link to comment Share on other sites More sharing options...
RaDi90Hybrid Posted April 3, 2010 Share Posted April 3, 2010 What bottom hose did you use ? The coolant inlet on the engine is a good bit lower than the rad so the hose is close to kinking. TIA Mo IIRC It was the standard Disco one but it was modified Quote Link to comment Share on other sites More sharing options...
RaDi90Hybrid Posted April 3, 2010 Share Posted April 3, 2010 Regarding the oil cooler lines, do standard Defender items do the trick, are they long enough ? TIA Mo Can't remember but if you are using the rad off the Disco check the Defender ones fit the unions. If you want to use the Disco ones you will just need to take them to a hydraulic place and get them made longer. Andy Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 3, 2010 Author Share Posted April 3, 2010 Thanks Andy, I've done that before but the cost was as high as new oil pipes, so, if defender ones will fit, I'd rather have the reassurance of having fitted new parts that require no modification. Mo Quote Link to comment Share on other sites More sharing options...
RaDi90Hybrid Posted April 3, 2010 Share Posted April 3, 2010 As I say, I think the unions on the ends are different for the Disco so the rad end may be a problem. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 3, 2010 Author Share Posted April 3, 2010 Thanks for that, I have a couple of sets of adapters here so I "should" be able to deal with that problem. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 3, 2010 Share Posted April 3, 2010 Rad end threads are different, but they just unscrew (30mm spanner/socket I think) Thread in the rad is the same, so unscrew the ones out of the Disco rad and fit them to the 90 one. Pipes are long enough. Les. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 4, 2010 Share Posted April 4, 2010 Mo, Is your engine in the 200 or 300 position? Mine is in the 300 position and the Disco 200 bottom hose works just fine. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 4, 2010 Author Share Posted April 4, 2010 It's in the 200 position, Bish Quote Link to comment Share on other sites More sharing options...
